new user questions
Posted: Fri Dec 09, 2011 8:47 am
Hi,
I got my by basic RA few days ago. Roberto, thank you, the shipping and packaging were excellent.
So far, I'm very impressed by the level of customization, how well it's made and user friendly (if you have windows). I'm a little disappointed for not having an ethernet port (too cheap to buy the wifi module) especially since I use mac and had to run windows on a virtual machine.
RAgen was used to generate my custom code.
Please let me know:
1. Ph related: I used pinpoint ph7 &10 to calibrate the ph probe: ph7 generated 530 and ph10 generated 840.
Are these numbers ok? After calibration, if I go back to the calibration menu I don't see those numbers anymore.
Do I have to calibrate everytime I compile a new program? How to avoid this?
2. ATO related: Since I'm planning to add a sump but there is no way to drill the tank I will use an HOB overflow. The ATO sensors will be mounted in the main tank (i think) and I'd like the high level ATO to control port 1 (ato pump ) and port 8 (main pump) to avoid overflow in the main tank.
3. Upgrade related: I didin't open the reef angel's case. How easy it will be to upgrade the arduino cpu? Lets say to add a faster arduino or an arduino ethernet or BT?
Thank you and keep up the excellent work.
Please let me know:
