Mounting of Probe and Float Switches
Posted: Wed Oct 22, 2014 1:06 pm
Other noob questions that I wish were answered in the user manual.
1) How to properly mount the PH probe? How far does it have to be in the water? is it ok if it is fully sumbersible? I know there are brackets for other PH Probes I have seen on BRS, but what does everyone use to hold it in position?
2) The Float switches that come with the controller. How to you keep these in position? The diagram says one has to be facing down and the other have to be facing up? What do you use to hold them in place? Also in the bag as an extra plastic nut and a rubber gasket. What do I use these for? The pics in the user manual seem like an older version of the hardware.
3) Temp sensor is about two degress off from my heater temp sensor. Is this normal? Is there any specs on the temp probe and how accurate it is +/- degrees?
4) When unplugging/plugging USB cable, does it matter if I unplug certain end first? Also it seems like pins allow for either direction, so I am just going off of the picture included with the user manual. It would be nice if it was more clear.
I am sure I will have more questions when I try to connect my jeabo adapters, but just starting off with basics.
