Will this code work for Dosing Pump
Posted: Fri Dec 09, 2011 2:52 pm
by JJones
I only want the dosing pump to turn on one time a day for one second--to dose vodka while I am out of town.
I am still new to coding, so want to make sure this code will accomplish that?
if (hour()==09 && minute()==0 && second()==1) //Alk Doser - Only works if Main screen is showing
ReefAngel.Relay.On(Port5); //Turn Doser on
ReefAngel.Relay.Off(Port5); //Turn Doser off
Re: Will this code work for Dosing Pump
Posted: Fri Dec 09, 2011 5:40 pm
You got it :)
At exactly 9:00:01 AM, you will get the dosing pump turning on for just that second.
Posted: Fri Dec 09, 2011 6:47 pm
That would work. My only comment would be to change the "09" to just be "9". The compiler may not like the 09. So you may want it to look like this:
if (hour()==9 && minute()==0 && second()==1)
Posted: Fri Dec 09, 2011 8:51 pm
by JJones
Thank you both
