Wave Pattern - custom & portal
Posted: Sun Oct 26, 2014 7:01 pm
by Smotz
'Lo all.
What would be the correct way to use both in code wave settings and the portal (when I want to) ?
In other words, how would I code my own wave settings when I choose 'custom' in the portal?
Re: Wave Pattern - custom & portal
Posted: Mon Oct 27, 2014 5:28 am
by cosmith71
Like this:
if (InternalMemory.DCPumpMode_read()==11)   // Custom mode on Portal
    ReefAngel.DCPump.SetMode(Else,60,30);
    if (hour()>=22 || hour()<9) ReefAngel.DCPump.SetMode(Gyre,70,10,31);  // Gyre mode 31 to 60 over 10 minutes from 2200 to 0900
    if (hour()>=9 && hour()<10) ReefAngel.DCPump.SetMode(Gyre,90,10,30);  // Gyre mode 30 to 90 over 10 minutes from 0900 to 1000
    if (hour()>=10 && hour()<11) ReefAngel.DCPump.SetMode(Else,50,20);
  else ReefAngel.DCPump.UseMemory = true;
Replace the stuff inside the {} with whatever you want to do when the portal is set to custom.
Posted: Mon Oct 27, 2014 5:44 am
by Smotz
cosmith71 wrote:Like this:
Awe man, this is absolutely perfect! Thank you.
Posted: Mon Oct 27, 2014 5:45 am
by cosmith71
You're welcome!
Posted: Mon Oct 27, 2014 8:04 pm
by Smotz
Does this nested 'if' look correct ? I am having a hard time switching using 'custom' on the portal. Seems unstable and sometimes doesn't work.
        //If 8am - 11am, Nutrient Transport
        if (wpMode==4)
        ReefAngel.PWM.SetDaylight( NutrientTransportMode(wpWavStr,wpWavOff,7000,true) );
        ReefAngel.PWM.SetActinic ( NutrientTransportMode(wpWavStr,wpWavOff,7000,false) );
              if (wpMode==5)
              ReefAngel.PWM.SetDaylight(wpWavStr);
              ReefAngel.PWM.SetActinic(wpWavStr);    //// Right wavemaker under feeder
                  //Set the wave
                  ReefAngel.PWM.SetDaylight( ElseMode(wpWavStr,wpWavOff,true) );
                  ReefAngel.PWM.SetActinic( ElseMode(wpWavStr,wpWavOff,false) );
Posted: Mon Oct 27, 2014 9:26 pm
by cosmith71
Try something like this:
        if (wpMode==4)
        if (wpMode==5)
         if (wpMode!=4 && wpMode!=5)
                  //Set the wave
No need for all the elses. They just make things confusing.
Posted: Tue Oct 28, 2014 5:08 am
by Smotz
cosmith71 wrote:Try something like this:
        if (wpMode==4)
        if (wpMode==5)
                  //Set the wave
Thanks bud. Definitely seems more elegant. Will try tonight!
Posted: Wed Oct 29, 2014 8:50 am
by Smotz
Can't seem to get this to work.
When I set 'custom mode' in the portal - my wave strength's are at 0. Works fine without the
    if (InternalMemory.DCPumpMode_read()==11) ReefAngel.DCPump.UseMemory = false;
Here's the full custom wave routine if anyone wants to help troubleshoot:
// Custom Wave Routine
// set the wpMode based on what time it is
    if ( (hour() >= 2) && (hour() < 5) ) wpMode=1;       // from 2am - 5am
    if ( (hour() >= 5) && (hour() < 8) )  wpMode=2;     // from 5am - 8am
    if ( (hour() >= 8) && (hour() < 11) ) wpMode=4;      // from 8am - 11am  Nutrient Transport
    if ( (hour() >= 11) && (hour() < 14) ) wpMode=2;     // from 11a - 2pm
    if ( (hour() >= 14) && (hour() < 17) ) wpMode=1;     // from 2pm - 5pm
    if ( (hour() >= 17) && (hour() < 20) ) wpMode=2;     // from 5pm - 8pm
    if ( (hour() >= 20) && (hour() < 23) ) wpMode=3;     // from 8pm - 11p
    if (hour() >= 23) wpMode=2;                          // from 11pm - midnight
    if (hour() < 2) wpMode=1;                            // from midnight - 2am
    if (ReefAngel.DisplayedMenu==FEEDING_MODE) wpMode=5;  // Feeding Mode
    if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) wpMode=6; //Water Change Mode
    switch (wpMode)
    case 1:  wpWavStr=30; wpWavOff=2; break;
    case 2:  wpWavStr=33; wpWavOff=4; break;
    case 3:  wpWavStr=35; wpWavOff=6; break;
    case 4:  wpWavStr=40; wpWavOff=50; break;
    case 5:  wpWavStr=29; wpWavOff=0; break;  // Feeding mode
    case 6:  wpWavStr=0; wpWavOff=0; break;   // Waterchange Mode
    default: wpWavStr=30; wpWavOff=2;
        if (wpMode==4)
        if (wpMode==5||wpMode==6)
        //Set the wave
    //end Custom Wave Routine
