need someone to write a code
Posted: Sun Nov 02, 2014 8:00 pm
cant for the life of me figure out how to write a code. can someone help me please??!! Thanks
http://forum.reefangel.com/
// Turn off Night Mode
if (hour()>8 && ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Night_Stop,0,0);
// Turn on Night Mode
if (hour()>20 && ReefAngel.RF.Mode!=Night) ReefAngel.RF.SetMode(Night,20,0);
if (hour()<8 || hour()>20) ReefAngel.RF.SetMode( ReefCrest,20,10 );
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//End of PWM Expansion Code Header
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,760,775 );
ReefAngel.StandardLights( Port2,20,0,4,0 );
ReefAngel.StandardLights( Port3,10,0,19,0 );
ReefAngel.StandardLights( Port4,9,0,20,0 );
ReefAngel.StandardLights( Port5,10,0,19,0 );
ReefAngel.StandardLights( Port6,9,0,20,0 );
// ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
// ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,19,0,0,100,0) );
// ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,19,0,0,100,0) );
ReefAngel.RF.SetMode( NutrientTransport,85,10 );
// Calculate your regular sunrise/sunset PWM value
PWMChannel[LEDPWM0]=PWMParabola(9,0,20,0,0,100,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMParabola(10,0,19,0,0,100,PWMChannel[LEDPWM1]);
PWMChannel[LEDPWM2]=PWMParabola(10,0,19,0,0,100,PWMChannel[LEDPWM2]);
CheckCloud();
ReefAngel.PWM.SetChannel( LEDPWM0, int(2.55*PWMChannel[LEDPWM0]));
ReefAngel.PWM.SetChannel( LEDPWM1, int(2.55*PWMChannel[LEDPWM1]));
ReefAngel.PWM.SetChannel( LEDPWM2, int(2.55*PWMChannel[LEDPWM2]));
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000001
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B000110
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
