Hello,
Just realized that my heater has not turned on and my tank temp dropped to 73. The heater had been working fine but now when it should be on its not. I can turn it on and off with the phone app but when I select auto nothing happens.
Is there something in my code that would cause this? Here's my code. Any help with this would be greatly appreciated.
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port8,13,30,22,30 );
ReefAngel.Relay.DelayedOn( Port2,3 );
ReefAngel.StandardHeater( Port3,79,80 );
ReefAngel.StandardATO( Port6,3600 );
ReefAngel.StandardLights( Port7,22,30,10,30 );
ReefAngel.Portal( "midwestornamental" , "****" );
Heater will not turn on
davaraj
Re: Heater will not turn on
I think you should replace this:
With this:
ReefAngel.StandardHeater( Port3,790,800);
With this:
- cosmith71
Yep, this. 79 degrees is 790, 79.2 degrees is 792. 7.9 degrees is 79.davaraj wrote:I think you should replace this:
With this:
- lnevo
- Contact:
i think we all have at some point.lnevo wrote:I've made that mistake myself..
