Why did my feed mode stop working after water change
Posted: Tue Nov 11, 2014 12:45 pm
by g6gang
static bool feedStart; // Flag to see when feed mode has started
static unsigned long feedTimer; // timer to track when to trigger the feeder
//static int powerUpdelay = 10000;
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit ;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
    // Ports that are start off
    ReefAngel.Relay.Off( Port1 );
    // Set Return Pump to 90%
    ReefAngel.PWM.SetDaylight(90);
    //delay(powerUpdelay);
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    //ReefAngel.Relay.DelayedOn( Port5,10 );
    //ReefAngel.Relay.DelayedOn( Port6,20 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.CustomLabels[0]="ATO";
    ReefAngel.CustomLabels[1]="Skimmer";
    ReefAngel.CustomLabels[2]="Fuge";
    ReefAngel.CustomLabels[3]="GFO";
    ReefAngel.CustomLabels[4]="Jabeo";
    ReefAngel.CustomLabels[5]="MP10";
    ReefAngel.CustomLabels[6]="Heater";
    ReefAngel.CustomLabels[7]="Return";
    ReefAngel.SingleATO( true,Port1,60,0 );
    ReefAngel.StandardHeater( Port7,708,810 );
if (ReefAngel.DisplayedMenu!=FEEDING_MODE) feedStart=false; // Reset the flag...
if (ReefAngel.DisplayedMenu==FEEDING_MODE && feedStart==false) {
  feedStart=true; // So we don't start the timer more than once per feeding mode.
  feedTimer=now(); // We're going to use this time to see if 2 minutes is up before we trigger the feeder.
if ( feedStart==false) // 2 min later activate auto feeder
  ReefAngel.PWM.SetDaylight(50);
    ReefAngel.Portal( "g6gang" );
I have the code running above for about a week now - all is good feed mode behavior working like a champ. I did a water change this weekend for the first time with RA (but clicking Water Change from local web server page). I could not figure out how to clear water change when I was done to turn all pumps back on. So I think I just clicked each pump relay via the local web page to turn everything back on.
So today I went to go into feed mode (using local web page) and nothing happened. No pumps shut off. So I am trying to figure out how things got out of sync and how to correct/ensure this does not happen again. I am going away for week and wifey will be in control of 'feeding' - concerned she will not turn everything back on and just want her to click the feed button.
On the Android app, the Water change mode flag current says 'off' as well as 'feeing mode'
I have not tried to reboot RA yet.
Re: Why did my feed mode stop working after water change
Posted: Tue Nov 11, 2014 12:59 pm
by g6gang
So i did a reboot and it seemed like it was back to normal. The question is why did this happen to begin with?
Posted: Tue Nov 11, 2014 1:03 pm
You need to end water change mode. You can click on Exit Mode in the U-App or click the joystick on the device or send /bp to the web interface. But that sounds like the reason things didnt work right.
