Power control expansion
pandimus
Is there any Manu control of it via the apps etc? I didn't happen to see it in the wizard, nor the menus in apps for manual control. I'm looking to control several things like pumps and fans and some control manually would be nice
- lnevo
Re: Power control expansion
It acts just like an additional relay bar. Yes you can control it in all the apps/portal/etc.
pandimus
So I just add it exactly like I has the expansion relay?
- lnevo
Yep you'll need to adjust the jumpers so it will have the right address if you already have an expansion.
pandimus
Thanks so much for your timelnevo wrote:Yep you'll need to adjust the jumpers so it will have the right address if you already have an expansion.
