Screen stays on / will not turn off
imfortney
Post by imfortney »
My RA+ has been running great! Recently one of my Jabeo pumps stopped working with the dimmer, so I switched it back to the stock controller and it works on that. The second wp10 that I have works on either dimmer port.
Anyways my main display started not timing out. I didn't change any code or equipment. I reloaded the code and same problem the wp10 doesn't work and the screen stays on.
Re: Screen stays on / will not turn off
It looks like thee Jebao cable.
Does it have any signs of water damage?
A good way to determine if it's the Jebao cable is to take the working cable and plug the non working pump in it.
If it the cable that is bad then the non working pump should work on the working cable.
You can also try the bad cable on the working pump, obviously that pump should not work.
imfortney
Post by imfortney »
Yea I'm going with the cable. But the screen has been on for at least a week now.
imfortney
Post by imfortney »
No water anywhere near the cable
So, did you test and found out it is indeed the cable following Sacohen steps?
