Screen stays on / will not turn off
Posted: Mon Nov 17, 2014 1:52 pm
by imfortney
My RA+ has been running great! Recently one of my Jabeo pumps stopped working with the dimmer, so I switched it back to the stock controller and it works on that. The second wp10 that I have works on either dimmer port.
Anyways my main display started not timing out. I didn't change any code or equipment. I reloaded the code and same problem the wp10 doesn't work and the screen stays on.
Re: Screen stays on / will not turn off
Posted: Mon Nov 17, 2014 2:12 pm
It looks like thee Jebao cable.
Does it have any signs of water damage?
Posted: Mon Nov 17, 2014 3:18 pm
by Sacohen
A good way to determine if it's the Jebao cable is to take the working cable and plug the non working pump in it.
If it the cable that is bad then the non working pump should work on the working cable.
You can also try the bad cable on the working pump, obviously that pump should not work.
Posted: Wed Nov 19, 2014 7:47 pm
by imfortney
Yea I'm going with the cable. But the screen has been on for at least a week now.
Posted: Wed Nov 19, 2014 7:48 pm
by imfortney
No water anywhere near the cable
Posted: Thu Nov 20, 2014 3:19 am
So, did you test and found out it is indeed the cable following Sacohen steps?
