Dc6000 and jebao cable
Posted: Sat Nov 22, 2014 2:39 am
Lots of questions from me at the moment..
So I invisioned using my dc6000 for my chiller and have it running at different speeds depending on the tank temp with my pwm expansion. No point having it running flat out if the chiller is off. Went to hook it up today and found that the plug is different than the jebao power head plugs. The male/female is switched around. So I cut the plug off the controller (mistake) thinking it should work fine once the right plug was on. Turns out it doesnt. I'm not sure why it would be any different to the power heads, but it doesn't work with the standard jebao cable. Anyone had experience with using pwm dimming on the return pumps?
