lcd not work afeter MB upgrade
Posted: Sun Nov 23, 2014 11:13 am
by lucamemini
Hi all,
I recently upgraded my old RA with RA+ motherboard ... but on the new MB the old LCD not work ... :(
Any idea?
This is my code:
boolean ATOerror=false;
/*********  configurazione di porte **************
port1: luce alba/tramonto (4000k / 3000k)
port2: luce notturna (led blu)
port3: Luce diurna (6000K - plafoniera)
port4: Pompe acqua (filtro e circuito co2 / raffreddamento)
port5: Elettrovalvola CO2
port6: Sistema di raffreddamento (condizionatore + ventole)
port7: Riscaldatore
port8: Pompa rabbocco automatico
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.AddWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port5Bit;
    InternalMemory.OverheatTemp_write( 300 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port7,245,255 );
    ReefAngel.StandardFan( Port6,260,275 );
    // luci diurne
    if (hour()<12) { //
      ReefAngel.StandardLights( Port1,7,30,12,0 ); // lampada singola
      ReefAngel.StandardLights( Port3,8,0,11,30 ); // plafoniera
    } else {
      ReefAngel.StandardLights( Port1,20,0,22,00 ); // lampada singola
      ReefAngel.StandardLights( Port3,16,0,21,00 ); // plafoniera
    // luce notturna -  Moonlights
    if ( hour() >= 21 && hour () <= 24 ) {
      ReefAngel.StandardLights( Port2,20,50,23,59 );
    } else if ( hour() >= 4 && hour () <= 8 ) {
      ReefAngel.StandardLights( Port2,5,00,8,00 );
    } else {
      ReefAngel.Relay.Off( Port2 );
    // ReefAngel.PHControl( Port5,690,822 );
    if (ReefAngel.Params. PH >= 725 ) {
      ReefAngel.Relay.On(Port5); // If sensor PH <= HighPH - turn on the CO2
    } else if (ReefAngel.Params. PH <= 680) {
      ReefAngel.Relay.Off(Port5); // If sensor PH <= HighPH - turn off the CO2
    } else {
      ReefAngel.StandardLights( Port5,7,0,20,00 ); // If sensor is beetween HighPH  and LowPH - turn on the CO2 from 7:00 to 20:00
    // LowATO = Tanica vuota, spengo la pompa se no si rovina
    // HighATO = Troppo pieno fermo la pompa prima di fare disastri
    if(!ReefAngel.LowATO.IsActive() || !ReefAngel.HighATO.IsActive()) {
        ReefAngel.LowATO.StopTopping();
        ReefAngel.HighATO.StopTopping();
        ReefAngel.Relay.Off(Port8);
        //ReefAngel.LED.On();
        ATOerror = true;
      } else {
        ReefAngel.WaterLevelATO(Port8,300,88,95); // 120 seconds timeout, turn on at 88% and turn off at 95%}
        ATOerror = false;
    ReefAngel.AddWifi();
Re: lcd not work afeter MB upgrade
Posted: Sun Nov 23, 2014 11:37 am
by lucamemini
ops... ok!
viewtopic.php?f=2&t=3111
