wiffi module
Posted: Mon Nov 24, 2014 4:43 pm
by iiluisii
is any body else having wifi module problems ?? my modules is been working on and off for the past 2 days after working flawless for ever. it was offline most of the day today and only connected for a few minutes then off again. The light still blinks green and my wifi router is working great cause everything else still works fine.. i also have a reeflnk running my Mp10 pumps and have not had a connection failure at all
Re: wiffi module
Posted: Wed Nov 26, 2014 8:02 am
by iiluisii
can someone give me a hand on this. the module worked again yesterday all day but around 1 AM this morning i received a reef tronic message saying it was down again and it has not worked since
Re: wiffi module
Posted: Wed Nov 26, 2014 8:37 am
Did you try moving it closer?
Re: wiffi module
Posted: Wed Nov 26, 2014 8:59 am
by iiluisii
its in the same placed its been and it has worked for month and the cable only allows me to have it a certain distance. and its only 15 to 20 feet away.
Re: wiffi module
Posted: Wed Nov 26, 2014 1:04 pm
by iiluisii
roberto if i disconnect the plug on the wire that connects to the controller coming from the wifi module and then connected again it will start working again
Re: wiffi module
Posted: Wed Nov 26, 2014 7:32 pm
Do you have 4.41 firmware?
You would need to use tera term and enter command mode to find out. Check the manual for more instructions on how to enter command mode.
Re: wiffi module
Posted: Thu Nov 27, 2014 12:14 pm
by iiluisii
just a question cause i don't know. what does the firm ware has to do with it?
Re: wiffi module
Posted: Thu Nov 27, 2014 12:20 pm
firmware updates usually come with bug fixes that may help your case.
Re: wiffi module
Posted: Thu Nov 27, 2014 1:36 pm
by iiluisii
when was the last firmware update pushed out for the wifi module
Re: wiffi module
Posted: Thu Nov 27, 2014 2:08 pm
Re: wiffi module
Posted: Fri Dec 05, 2014 2:23 pm
by iiluisii
Roberto Found what's causing the problem.
If I leave the app running on my phone for a while it cause the issue. But if I close down the app after each use the wifi module stays connected without a problem
Re: wiffi module
Posted: Fri Dec 05, 2014 2:27 pm
Which app is causing that?
Re: wiffi module
Posted: Fri Dec 05, 2014 2:31 pm
by iiluisii
I'm using the app u
Re: wiffi module
Posted: Fri Dec 05, 2014 3:07 pm
Re: wiffi module
Posted: Fri Dec 05, 2014 4:30 pm
by iiluisii
I'm using the android version. Now that you ask it brought it to my attetion that It started happening after I switch to my note 4 from the iPhone 5 it never happened to me while I was using the app on the iPhone
Re: wiffi module
Posted: Tue Dec 09, 2014 3:13 pm
by iiluisii
Any help would be great
Re: wiffi module
Posted: Wed Dec 10, 2014 8:36 pm
by iiluisii
Still cant figure out the problem. It works just fine if I close app. But the minute I forget to close it stops working and I have to disconnect it and reconnect it to make it work
Re: wiffi module
Posted: Wed Dec 10, 2014 9:57 pm
Try disabling the auto refresh
