diming expansion start time
Ademster
Post by Ademster »
how do I code to have lets say channel 3 of the dimming expansion module to come on few minutes before channel 2 and then few minutes later channels 1-2-4 come on and start the normal ramp up durration
Adam
58 Gal
Re: diming expansion start time
When do you want channel 3 to go off in relation to 1-2-4?
Ademster
Post by Ademster »
5min before and after,
my light cycle is currently 11-8
I do have code saved to internal memory, if that changes anything.
Adam
58 Gal
So you just give it a 5 as the offset.
So if you have ReefAngel.PWM.Channel2PWMSlope();
You'd do
ReefAngel.PWM.Channel3PWMSlope(5);
Ademster
Post by Ademster »
okay thanks, I will give it a test when i am done doing my coding for the new lights.
adam
Adam
58 Gal
