Updating WIFI firmware
Posted: Sat Dec 13, 2014 9:42 am
by cjrudy
Having trouble with the wifi module so I need to update the firmware, totally forgot how to do it, where can I get the instructions again ?
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: Updating WIFI firmware
Posted: Sat Dec 13, 2014 10:04 am
If you log into the wifi attachment in command mode, you can use this command:
Check the manual for instructions on how to enter command mode.
Posted: Sat Dec 13, 2014 4:16 pm
by cjrudy
Well I logged in, used ftp u and it connected to the ftp but they just ran these continual gray lines of nothing, very strange.
So After 20 minutes I disconnected, reset to factory settings and now I cannot get it to take wifi settings through the wifi utility and I cannot log in through putty.
Posted: Sat Dec 13, 2014 4:23 pm
factory settings restore baud rate back to 9600.
Try following these then:
The latest firmware is 4.41. Which version do you have now?
Posted: Sat Dec 13, 2014 4:42 pm
by cjrudy
I had gone back to 9600 baud and was finally able to get in, ran the wifi set up through command line, but after reboot it still never connected. Now I cant get back in........GRR !!!
Posted: Sat Dec 13, 2014 4:46 pm
by cjrudy
OK , just got back in, firmware actually did upgrade to 4.4.1, still cant get wifi to set up, either through putty or the wifi utility
Posted: Sat Dec 13, 2014 5:07 pm
by cjrudy
get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-c6
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=0.0.0.0:2000
NM=255.255.255.0
GW=0.0.0.0
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=5
IdleTimer=0
CmdChar=$
DNS=0.0.0.0
Name=dns1
Backup=rn.microchip.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=NETGEAR07
Chan=0
ExtAnt=0
Join=0
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=30
Passphrase= XXXXXXXXXXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
Here is what I got
Posted: Sat Dec 13, 2014 5:27 pm
SSID and passphrase are case sensitive.
Can you make sure you have the exact same case?
Posted: Sat Dec 13, 2014 5:28 pm
Also, Join needs to be 1 if you manually set it up.
If you run the macro, it will set it to 1 automatically.
Posted: Sat Dec 13, 2014 5:35 pm
by cjrudy
Verified SSID and Passphrase, set join to 1, still nothing
<4.41> get e
SSID=WiFly-GSX-c6
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=0.0.0.0:2000
NM=255.255.255.0
GW=0.0.0.0
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1024
MatchChar=0
FlushTimer=5
IdleTimer=0
CmdChar=$
DNS=0.0.0.0
Name=dns1
Lease=86400
FTP=0.0.0.0:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=NEATGEAR07
Chan=0
ExtAnt=0
Join=1
Auth=MIXED
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=30
Passphrase=C4/29L11/29A10/11M4/7
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-GSX
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
Posted: Sat Dec 13, 2014 6:04 pm
use command
and post the results
Posted: Sun Dec 14, 2014 7:08 am
by cjrudy
CMD
scan
<4.41>
SCAN:Found 1
01,07,-53,04,1104,28,40,84:1b:5e:dc:67:9c,NETGEAR07
END:
Posted: Sun Dec 14, 2014 11:05 am
Your SSID is set to NEATGEAR07 and your scan produced NETGEAR07
Posted: Sun Dec 14, 2014 11:31 am
by cjrudy
The set wlan join 1 and correcting the SSID did it.
Thanks for all your help
