My best bet?
Posted: Mon Dec 15, 2014 2:29 pm
by pandimus
Hey all.. I need a new piece of equipment, but debating what would be best.. I currently have
Ra+, with pwm relay modded 0-5v, pwm dimmer expansion 0-5v old style that cannot be changed to analog
Power Control. Module
Expansion module..
I need to control
2x jebao and 1xwaveline
2x Apollo led.
What I am debating..
I can either get analog dimmer expansion this way I believe I'll have no. More use for my pwm expansion
Or for 10 dollars more I could get analog relay expansion have more ports, but I'm not sure if I can control my pumps with the pwm expansion..
What do you guys think is my best bet?
Re: My best bet?
Posted: Mon Dec 15, 2014 4:08 pm
The jaebo pumps can be controlled by either analog or pwm. The new dimming expansions have jumpers and can be configured by channel for pwm or analog and 0-10v or 0-5v
Re: My best bet?
Posted: Mon Dec 15, 2014 4:32 pm
by pandimus
I was aware the new expansion modules ability to change with jumpers.. I bought a few months to early I guess.. Thanks for the feedback.. So for controlling the jebaos and the waveline the pwm 0-5v dimmer will work fine? So I could conceivably just buy an analog relay module and I'll be good?
Re: My best bet?
Posted: Mon Dec 15, 2014 5:40 pm
I believe you need to mod the cable but it is doable.
Re: My best bet?
You will not be able to use the dimming on the relay expansion
Re: My best bet?
Posted: Mon Dec 15, 2014 6:03 pm
by pandimus
lnevo wrote:You will not be able to use the dimming on the relay expansion
I was planning on moving my current relay to the expansion and using new one as primary.. That possible right?
Re: My best bet?
Posted: Mon Dec 15, 2014 6:04 pm
Yes. Exactly
Re: My best bet?
Posted: Mon Dec 15, 2014 6:37 pm
by pandimus
Thank you.. I'll get a relay expansion on order..
