I am building a new aquarium system and in it I have numerous pumps and lights that are all 0-10V control. I have exceeded the 6 channels on the dimming expansion (+ the 2 on the head). Is it possible to add a second dimming expansion to the system?
Don
Multiple Dimming Expansions
- lnevo
Re: Multiple Dimming Expansions
Nope. You can however request a 16ch expansion.
- lnevo
Also you have the option to use your float switch ports as pwm which could control your pumps if you modify the cable to use 0-5V instead of 0-10V
Well, technically you can still have another module too.
There is a jumper inside the current 6h module that changes its address, so you can still control it.
There is no interaction with any of our apps though.
So you won't see status in the Portal or any phone apps.
dedvalson
Is there a 16 ch expansion??lnevo wrote:Nope. You can however request a 16ch expansion.
