RANet relay expansion not working
Posted: Sun Dec 21, 2014 9:52 am
by grafxalien
I tried to hook up my ranet relay expansion today. None of the outlet seems to work. Even when I set them to always on. I flipped the 1st switch on. 2 and 3 are off on the side. Also, there are 2 ports that I cant plug anything in to because the copper inside is bent. Is this fixable?
here is my code:
#include <SoftwareSerial.h>
    InternalMemory.LCDID_write(255);
    ReefAngel.AddRANet();  // RANet Add-On Module
    ReefAngel.FeedingModePortsE[0] = Port3Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port4Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit;
    ReefAngel.LightsOnPorts = Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.StandardFan( Port1 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardATO( Port4 );
    ReefAngel.Relay.DelayedOn( Port5 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.Relay.Set( Box1_Port2, !ReefAngel.Relay.Status( Port2 ) );
    ReefAngel.DayLights( Box1_Port3 );
    ReefAngel.DayLights( Box1_Port4 );
    ReefAngel.Portal( "grafxalien" );
Re: RANet relay expansion not working
Posted: Sun Dec 21, 2014 9:54 am
You should leave them all off (up position) That's the id for Box1
Posted: Sun Dec 21, 2014 10:11 am
by grafxalien
thanks, that fixed it. I used a small screwdriver and was able to bend some of the copper in the two outlets the didnt allow me to plug anything in. That seemed to fix it. Still a little rough plugging things in them though
Posted: Sun Dec 28, 2014 7:14 am
by grafxalien
another question about the expansion. I just go back in town after getting it setup. Last night I noticed that every 10-20 min my refugium light would turn off for a second then right back on. This light is hooked up to the wireless relay expansion. I think the expansion is losing connection to RANET, turning it off then back on. The box is only ~3 feet away from the controller. Is there any way to check/fix this problem?
Posted: Sun Dec 28, 2014 11:08 am
That does look like loss of connection.
The way the loss of connection is handled right now is if the module does not receive data for 2 seconds or if the data gets corrupted over the air when being transmitted, it will assume loss of connection and will enter into fall back mode.
Maybe we can increase this limit.
The only problem is that it is not easy to reprogram the firmware of the box.
It requires disassemble of the box to pull out the RANet receiver module inside of it.
Posted: Sun Dec 28, 2014 6:15 pm
by grafxalien
does a re-program require it to be pulled out and sent back to you?
Posted: Sun Dec 28, 2014 6:19 pm
The reprogram can be done by you if you are willing to open it up and try.
I'll put together some instructions shortly.
Posted: Mon Dec 29, 2014 12:40 pm
by grafxalien
i have some time off this weekend so I could give it a shot as long as I don't need any special equiptment
Posted: Mon Dec 29, 2014 6:26 pm
Open the enclosure box
Remove all screws to free up the board inside.
You should be able to pry the board from the outlets.
Pay attention to the Logo LED lead wires. Make sure to disconnect when separating the pcb from the outlets/box.
With the pcb in your hand, you will see the RANet Receiver
Detach and look underneath. One of the 6pin headers has a GND marking. That's the black wire of the programming cable you use to program RA.
Connect the programming cable to the RANet Receiver.
Go to Arduino and make sure to change the board to ReefAngel w/ optiboot
Load the code below to the RANet Receiver.
#include <avr/eeprom.h>
#define BLUE_LED    9
#define WHITE_LED   10
#define BLUE_INTENSITY   255
#define WHITE_INTENSITY  255
#define RANET_MAX_SIZE  64
#define DISCONNECT_TIMEOUT  10000
#define LastFallback0  100 // Memory location for fallback storage
#define RANet_Down    0
#define RANet_OK      1
byte buffer_index;
byte buffer[128];
char buf[3];
byte bufint, bufsize;
byte RANetData[RANET_MAX_SIZE];
byte RANetCRC;
byte BlueChannel=0;
byte WhiteChannel=0;
byte RANet_Status=RANet_Down;
boolean cable_present=false;
unsigned long lastcablecheck=millis();
  pinMode(BLUE_LED,OUTPUT);
  pinMode(WHITE_LED,OUTPUT);
  Serial.begin(57600);
  Wire.onReceive(NULL);
  Wire.onRequest(NULL);
  Wire.begin();
  for (int a=0;a<RANET_MAX_SIZE; a++) // Clear array
    RANetData[a]=0;
  Wire.beginTransmission(0x68);
  Wire.write(0);
  int a=Wire.endTransmission();
  cable_present=(a==0);
  // setup PCA9685 for data receive
  // we need this to make sure it will work if connected ofter controller is booted, so we need to send it all the time.
  Wire.beginTransmission(0x40);
  Wire.write(0);
  Wire.write(0xa1);
  if (cable_present)
    BlueChannel=100;
    WhiteChannel=0;
    analogWrite(WHITE_LED,WHITE_INTENSITY*WhiteChannel/100);
    analogWrite(BLUE_LED,BLUE_INTENSITY*BlueChannel/100);
    BlueChannel=0;
    WhiteChannel=0;
    while(Serial.available())
      UpdateWhiteChannel();
      char c = Serial.read(); // Read each incoming byte
      buffer[buffer_index]=c; // store in the buffer array
      if (c==10) // if line feed we analyze the payload
        if (buffer_index>25) // only need to analyse if buffer_index is greater than 25, otherwise the payload is broken or corrupt
          if (buffer_index==buffer[1]) // check if payload matches the length the controller sent
            RANetCRC=0;
            for (int a=0; a<(buffer_index-2); a++) // calculate CRC
              RANetCRC+=buffer[a];
            if (RANetCRC==buffer[buffer_index-2]) // if CRC matches
              for (int a=0; a<(buffer_index-2); a++) // Copy buffer to RANetData
                RANetData[a]=buffer[a];
  //            Serial.print(millis());
  //            Serial.print("\t");
  //            Serial.println(RANetData[2]);
              for (int a=0;a<8;a++)
                if (eeprom_read_byte((unsigned char *) LastFallback0+a)!=RANetData[10+a])
                  eeprom_write_byte((unsigned char *) LastFallback0+a, RANetData[10+a]);
                Wire.beginTransmission(0x38+a);
                Wire.write(~RANetData[2+a]);
              for (int a=0;a<6;a++)
                int newdata=(int)(RANetData[18+a]*40.95);
                Wire.write(0x8+(4*a));
                Wire.write(newdata&0xff);
                Wire.write(newdata>>8);
              RANet_Status=RANet_OK;
        buffer_index=255; // reset buffer index
      if (buffer_index++>=128) buffer_index=0; // increment index of buffer array. reset index if >=128
    if (millis()-lastmillis>DISCONNECT_TIMEOUT)
  //    Serial.println("Disconnected");
  //    Serial.println(RANetData[10]);
        Wire.write(~eeprom_read_byte((unsigned char *) LastFallback0+a));
    if (RANet_Status==RANet_Down)
        BlueChannel=0;
        WhiteChannel=millis()%2000<1000?0:100;
void UpdateWhiteChannel()
  WhiteChannel=sin(radians((millis()%7200)/40))*255;
  BlueChannel=255-(sin(radians((millis()%7200)/40))*255);
  analogWrite(WHITE_LED,WhiteChannel);
  analogWrite(BLUE_LED,BlueChannel);
Let me know if you have any questions.
Posted: Tue Dec 30, 2014 3:55 am
by cosmith71
I just happen to have a pic of the RANet receiver. This is what you're looking for.
RANet Receiver.jpg (185.94 KiB) Viewed 9731 times
RANet Receiver Top.jpg (111.49 KiB) Viewed 9731 times
Posted: Sat Jan 03, 2015 2:46 pm
by bencollinz
how did you get relay box to work? Mine is just flashing white at me...
my code
    #define Heater      1
    #define Return      2
    #define HeaterTk2   3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
    #define Sump Light  8
byte vtechmode, vtSpeed, vtDuration;
        ReefAngel.FeedingModePorts = Port2Bit;
        // ReefAngel.FeedingModePortsE[0] = 0;
        // ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        // ReefAngel.WaterChangePortsE[0] = 0;
        // ReefAngel.LightsOnPorts = 0;
        // ReefAngel.LightsOnPortsE[0] = 0;
        // ReefAngel.OverheatShutoffPortsE[0] = 0;
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port4 );
        // Hardcode calibrations
        ReefAngel.PHMin=576; // PH7.0
        ReefAngel.PHMax=842; // PH10.0
        ReefAngel.SalMax=3300; // 35ppt
    vtechmode=InternalMemory.RFMode_read();
    vtSpeed=InternalMemory.RFSpeed_read();
    vtDuration=InternalMemory.RFDuration_read();
    static unsigned long feeding;
    ReefAngel.StandardHeater( Port1,778,782 );
        ReefAngel.WaterLevelATO( Port7,180,71,74 );
        ReefAngel.StandardLights( Port8,15,0,2,0 );
        ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) );  //MOON
        ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) );  //RB
        ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE
        ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) );  //BLUE&CYAN
        ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
        if ( ReefAngel.HighATO.IsActive())
          ReefAngel.Relay.On(Port2);
          ReefAngel.Relay.Off(Port2);
if (hour() >=13 && hour() < 20)
        // if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
        ReefAngel.RF.UseMemory=true;
        // ReefAngel.RF.SetMode(ReefCrest,60,20);
             feeding=now();
             if (now()-feeding<5400) {
            // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 60 minutes after feeding mode.
  ReefAngel.RF.UseMemory=false;
    ReefAngel.RF.SetMode(Smart_NTM,75,10);
        ReefAngel.RF.SetMode(Constant,10,0);
         if (vtechmode!=InternalMemory.RFMode_read())
          InternalMemory.RFMode_write(vtechmode);
         if (vtSpeed!=InternalMemory.RFSpeed_read())
          InternalMemory.RFSpeed_write(vtSpeed);
         if (vtDuration!=InternalMemory.RFDuration_read())
          InternalMemory.RFDuration_write(vtDuration);
        ReefAngel.Portal( "bencollinz" );
      char text[7];
        // Date and Time
        ReefAngel.LCD.DrawDate( 6, 2 );
    ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
  ReefAngel.LCD.Clear(255,59,29,128,39);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
  ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
 /* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
  // water level
    ReefAngel.LCD.DrawText(0,255,68,58,"WL");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
       // Main Relay Box
        ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
         // Relay Expansion
       ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
    /* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
    void Heater1(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
Posted: Sat Jan 03, 2015 2:54 pm
by cosmith71
Put this is in setup()
Posted: Sat Jan 03, 2015 3:40 pm
by bencollinz
cosmith71 wrote:Put this is in setup()
Thank you! Found it shortly after I asked, go figure.
Posted: Sun Jan 04, 2015 1:10 pm
by bencollinz
grafxalien wrote:another question about the expansion. I just go back in town after getting it setup. Last night I noticed that every 10-20 min my refugium light would turn off for a second then right back on. This light is hooked up to the wireless relay expansion. I think the expansion is losing connection to RANET, turning it off then back on. The box is only ~3 feet away from the controller. Is there any way to check/fix this problem?
I'm having this issue as well. My main lights keep flashing.
Posted: Sun Jan 04, 2015 2:18 pm
by cosmith71
Did you try this?
rimai wrote:Open the enclosure box
#define BLUE_LED    9
#define RANet_OK      1
byte buffer_index;
byte buffer[128];
char buf[3];
byte RANetCRC;
byte BlueChannel=0;
  Wire.begin();
    RANetData[a]=0;
  Wire.write(0);
  Wire.write(0);
  Wire.write(0xa1);
  if (cable_present)
    BlueChannel=100;
    WhiteChannel=0;
    BlueChannel=0;
    WhiteChannel=0;
            RANetCRC=0;
        BlueChannel=0;
Posted: Wed Jan 07, 2015 3:41 pm
by bencollinz
cosmith71 wrote:Did you try this?
I just did this. We'll see if it helps.
Here are some pictures for others in the future:
"You should be able to pry the board from the outlets."
I was a little disappointed to see that ALL of these black boxes were not pushed onto the board all the way
there fixed it
"Pay attention to the Logo LED lead wires. Make sure to disconnect when separating the pcb from the outlets/box."
continued below...
Posted: Wed Jan 07, 2015 3:43 pm
by bencollinz
"With the pcb in your hand, you will see the RANet Receiver"
"Detach and look underneath. One of the 6pin headers has a GND marking. That's the black wire of the programming cable you use to program RA."
"Connect the programming cable to the RANet Receiver."
Posted: Mon Jan 12, 2015 2:26 pm
by bencollinz
This still occurs. Just not as frequently.
Posted: Wed Jan 14, 2015 9:18 am
Did you confirm that the box requires 10 seconds now to assume connection loss?
Posted: Mon Jan 26, 2015 1:50 pm
by bencollinz
rimai wrote:Did you confirm that the box requires 10 seconds now to assume connection loss?
yes. 10 seconds.
