What does this code do?
Posted: Sun Dec 21, 2014 7:15 pm
by cosmith71
Too much punctuation! Can somebody 'splain?
WhiteChannel=millis()%2000<1000?0:100;
Re: What does this code do?
Posted: Sun Dec 21, 2014 7:23 pm
StartTIme+Offset%Repeat<RunTime is the basis for most of the timechecks. You arent using the offset above but if you wanted thats how it works.
The ?0:100 is like an if else so if the condiction prior is true then 0 else 100
Posted: Sun Dec 21, 2014 7:29 pm
by cosmith71
lnevo wrote:StartTIme+Offset%Repeat<RunTime is the basis for most of the timechecks. You arent using the offset above but if you wanted thats how it works.
You hurt my brain a little just then.
So, does this mean if millis mod 2000 is less than 1000 then WhiteChannel=0 else WhiteChannel=100?
Posted: Sun Dec 21, 2014 7:30 pm
Why yes, yes it does
Posted: Sun Dec 21, 2014 7:34 pm
by cosmith71
