Just ordered Pwm unit with wifi
Posted: Fri Dec 26, 2014 7:02 pm
by Reefology
Merry Xmas,
As mentioned in title, just ordered a reef angel and am looking forward to automating my system. I know from some of the things I've read, it can get fairly complex. I really need basic functionality but I would like to get it right from the onset and then forget it.
I've already downloaded the manuals for both the unit and wifi attachment and skimmed through them. I like the preloaded functionality but don't need a auto top off or circulation pump so would like to replace port 1 & 8 with/for dosing pumps?
Also, I have Chinese led's and wanted to know if the preloaded code is already set up to dim them?
Re: Just ordered Pwm unit with wifi
Posted: Fri Dec 26, 2014 9:35 pm
by pandimus
The wizard will help you in all your endeavors.. You can download the installer and have a whirl at it before your unit arrives.. Basic functions this thing can do easily... Don't worry about that.. It's later on that you say hmmm, I want to try...
Your Chinese leds do that have a dimming port? If so you should be set.. As the reef angel has two dimming ports already..
Posted: Sat Dec 27, 2014 4:01 am
Which Chinese LED? You may need to hack the unit to add the dimming port. You can buy a kit from Reef Radiance or you can do it yourself.
Posted: Sat Dec 27, 2014 7:12 am
by Reefology
Thank you for the reply
Pandimus:
No doubt I will want to tinker at some point down the road :)
My LEDs have dimming capabilities but not sure about ports?
Where do I find the wizard installer?
Inevo:
Any info in regards to doing it myself?
My LEDs are the AquaSTAR-165W-Dimmable-LED-Aquarium-Light-Full-Spectrum-Reef-Coral-Fish-Marine-/301181689222
Posted: Sat Dec 27, 2014 7:38 am
Yeah those should work. You can buy the kit here http://reefradiance.com/reef-radiance-prostar-165.html or you can get the parts and do it yourself. If you're on Facebook you could join the Chinese Blackbox LED Proof Group and they have a pinned post with how to do the hack.
