jebao cables w/ w25 pump
Posted: Sun Dec 28, 2014 5:05 pm
by Civics14
Hi all,
Do I need to power this from the RA+ relay box when I have it controlled with the Jebao cable attachment? Or can it be plugged into my power station?
Thank you
Re: jebao cables w/ w25 pump
Posted: Sun Dec 28, 2014 5:27 pm
by pandimus
What's a power station?
Posted: Sun Dec 28, 2014 5:28 pm
by pandimus
It has to be plugged into the relay, and you have to use the power cable that came with your jebao
Posted: Sun Dec 28, 2014 6:43 pm
It can be plugged into a non RA relay if you want to save ports. I think it would draw too many amps for the power station.
Pandimus, the power station is a relay box with 12V dc out instead of 110 ac
Posted: Sun Dec 28, 2014 6:49 pm
by pandimus
I figured that is what he meant.. But I thought it was called power control... Isn't the jebao power supplies 48v?
Posted: Sun Dec 28, 2014 6:50 pm
by pandimus
Error 24v
Posted: Sun Dec 28, 2014 9:08 pm
by Civics14
pandimus wrote:What's a power station?
American DJ PC-100a
Posted: Sun Dec 28, 2014 9:10 pm
by pandimus
Civics14 wrote:pandimus wrote:What's a power station?
American DJ PC-100a
That's exactly how I do it.. But I call it a day strip...
Posted: Sun Dec 28, 2014 9:43 pm
No, there's a reef angel power station module that is a relay box but for 12vdc devices.
Posted: Mon Dec 29, 2014 6:18 am
by cosmith71
The answer to the original question is you can plug the Jebao power supply into any AC outlet. Doesn't have to be the relay box.
Posted: Mon Dec 29, 2014 7:30 am
by Civics14
cosmith71 wrote:The answer to the original question is you can plug the Jebao power supply into any AC outlet. Doesn't have to be the relay box.
Thank you Colin
