Why am I having this error?
Posted: Fri May 06, 2011 11:09 am
by paulo.hanashiro
This is my file header:
// Autogenerated file by RAGen (v1.0.3.79), (05/02/2011 22:20)
// RA_050211_2220.pde
#define VersionMenu
#define wifi
#define RelayExp
#define SaveRelayState
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
// Timer used to indicate when to dump the parameters
ReefAngel_TimerClass ParamTimer;
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "phanashiro";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe3_label[] PROGMEM = "Not%20Used";
prog_char relay1_label[] PROGMEM = "Skimmer";
And found this error:
RA_050211_2220.cpp.o: In function `loop':
C:\Users\PH250023\AppData\Local\Temp\build6451466237859308872.tmp/RA_050211_2220.cpp:94: undefined reference to `ReefAngelClass::WebBanner()'
RA_050211_2220.cpp.o: In function `setup':
C:\Users\PH250023\AppData\Local\Temp\build6451466237859308872.tmp/RA_050211_2220.cpp:62: undefined reference to `ReefAngelClass::LoadWebBanner(int, unsigned char)'
I have no idea about what is causing this error.
Can somebody help me to fix this?
Thanks..
Paulo
Re: Why am I having this error?
Posted: Fri May 06, 2011 11:37 am
What version of the libraries are you using?
Those define statements at the top:
#define VersionMenu
#define wifi
#define RelayExp
should be inside the ReefAngel_Features.h file and not inside the PDE file. If they are not there, specifically the #define wifi, then those two functions WebBanner() and LoadWebBanner(int, unsigned char) will not be available at compile time.
So please verify that they exist in the ReefAngel_Features.h file (ReefAngel_Features/ReefAngel_Features.h), if they do not exist, add them in and save the file. Then try recompiling.
Posted: Fri May 06, 2011 11:55 am
by paulo.hanashiro
Thanks Curt.!!!
It's working now!!!
