Web portal and banner update issue
Posted: Mon Dec 29, 2014 5:48 pm
by sesame
a really strange things happened with my portal and banner.
last month, portal always shown latest updated in 25 Nov. Initially, i thought its a wifi device issue. Update firmware, check code and router, but doesn't work.
fortunately, as stare at portal site 5 min, it suddenly update to current status.
now problem is
1. portal always shown updated in 25 Nov as website initial login or refresh. but will updated to current status itself without refresh.
2. web banner always 25 Nov.
3. remote iphone app and web server working good.
is there something i can do to fix this issue?
initial login shown below:
Reef Angel wifi address: xxxxx.xxxxxxx.org:2000
My reefangelid: sesame
Connection Status: Ready
Last Update:2014/11/25 8:18:46
Displaying data from: Reef Angel Controller (live)
initial After 5 min:
Last Update: 2014/12/30 8:41:37
Re: Web portal and banner update issue
Posted: Mon Dec 29, 2014 5:50 pm
Check if your portal key is disabled. If enabled, make sure your code includes it.
Posted: Mon Dec 29, 2014 6:59 pm
by sesame
no password required in code or website setting.
Posted: Mon Dec 29, 2014 7:04 pm
Do you have this in your code?
Posted: Mon Dec 29, 2014 7:05 pm
by sesame
definitely
Posted: Mon Dec 29, 2014 7:15 pm
To confirm, let's try this.
Connect the programming cable to RA.
Open Arduino and go to menu Tools->Serial Monitor
Make sure you have 57600 baud selected on the bottom right corner.
Leave it there for 15 to 20 minutes.
Post whatever you see in the window.
Posted: Mon Dec 29, 2014 9:41 pm
by sesame
thank you
let me have a try
Posted: Mon Dec 29, 2014 9:44 pm
by sesame
connected with Tera term and checked. seems wifi model already in 57600.
nothing happened.
Posted: Mon Dec 29, 2014 9:59 pm
Not the wifi.
You need to connect to RA.
I want to make sure RA is sending data to the module correctly every 5 minutes.
Posted: Mon Dec 29, 2014 11:04 pm
by sesame
ok got it
Posted: Tue Dec 30, 2014 7:22 am
by sesame
stare at least 20min, nothing happened in monitor window.
is there anything wrong with my RA+?
Posted: Tue Dec 30, 2014 7:52 am
Were you using teraterm or the Serial Monitor inside the Arduino app. Can you post your full code. Can you upload the code again and then monitor again via the serial monitor.
Posted: Tue Dec 30, 2014 7:58 am
by sesame
my code as attached
// Define Relay Ports by Name
#define Return 1
#define ATOPump 2
#define Skimmer 3
#define Wavepump 4
#define None1 5
#define ZeovitShake 6
#define Relay_Box2 7
#define Heater 8
#define T5_Channel1 Box1_Port1
#define T5_Channel2 Box1_Port2
#define T5_Channel3 Box1_Port3
#define ZEO_ST3 Box1_Port4
#define ZEO_SP Box1_Port5
#define CaHCO3 Box1_Port6
#define ZEO_BB Box1_Port7
#define ZEO_KB Box1_Port8
ReefAngel.FeedingModePorts = Port8Bit | Port4Bit | Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port8Bit; //should be redefine to new ports
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Wavepump);
ReefAngel.Relay.On(Relay_Box2);
ReefAngel.CustomLabels[0]="ReturnPump";
ReefAngel.CustomLabels[1]="ATOPump";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="Wavepump";
ReefAngel.CustomLabels[4]="None1";
ReefAngel.CustomLabels[5]="ZeovitShake";
ReefAngel.CustomLabels[6]="Relay_Box2";
ReefAngel.CustomLabels[7]="Heater";
//single ATO
ReefAngel.SingleATO(true,ATOPump,90,1);
// T5 light setup
//ReefAngel.MoonLights(LunaLED);
ReefAngel.DosingPumpRepeat1(ZeovitShake);
ReefAngel.StandardLights(T5_Channel2);
ReefAngel.PWM.SetChannel(0,ReefAngel.Relay.Status(T5_Channel1)*100);
ReefAngel.DayLights(T5_Channel1);
ReefAngel.PWM.SetChannel(1,ReefAngel.Relay.Status(T5_Channel3)*100);
ReefAngel.ActinicLights(T5_Channel3);
ReefAngel.PWM.SetChannel(2,ReefAngel.Relay.Status(T5_Channel2)*100);
//dosing pump setup
ReefAngel.DosingPump(ZEO_ST3,1,22,31,28);
ReefAngel.PWM.SetChannel(3,ReefAngel.Relay.Status(ZEO_ST3)*100);
ReefAngel.DosingPump(ZEO_ST3,2,6,31,28);
ReefAngel.DosingPump(ZEO_SP,4,22,32,40);
ReefAngel.PWM.SetChannel(4,ReefAngel.Relay.Status(ZEO_SP)*100);
ReefAngel.DosingPumpRepeat2(CaHCO3);
ReefAngel.PWM.SetChannel(5,ReefAngel.Relay.Status(CaHCO3)*100);
//wave pump setup
if (now() % SECS_PER_DAY >= 9 * SECS_PER_HOUR && now() % SECS_PER_DAY < (9 * SECS_PER_HOUR + 10 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(Lagoon,90,20);//Set RW8 to 90% speed with pulse in Lagoon Mode from 9:00~9:10
else if (now() % SECS_PER_DAY >= (9 * SECS_PER_HOUR + 10 * SECS_PER_MIN) && now() % SECS_PER_DAY < 10 * SECS_PER_HOUR )
ReefAngel.DCPump.SetMode(TidalSwell,90,20); //Set RW to 90% speed with 20ms pulse in Tidal Swell Mode
else if (now() % SECS_PER_DAY >= 10 * SECS_PER_HOUR && now() % SECS_PER_DAY < (10 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(ReefCrest,85,20);//Set RW8 to 85% speed with Lagoon Pulse Mode
else if (now() % SECS_PER_DAY >= (10 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now() % SECS_PER_DAY < (11 * SECS_PER_HOUR + 10 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(Lagoon,85,20);//Set RW8 to 85% speed with pulse in Lagoon Mode
else if (now() % SECS_PER_DAY >= (11 * SECS_PER_HOUR + 10 * SECS_PER_MIN) && now() % SECS_PER_DAY < (12 * SECS_PER_HOUR + 0 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(LongPulse,85,30);;//Set RW8 to 85% speed with Long pulse Mode
else if (now() % SECS_PER_DAY >= (12 * SECS_PER_HOUR + 0 * SECS_PER_MIN) && now() % SECS_PER_DAY < 15 * SECS_PER_HOUR )
ReefAngel.DCPump.SetMode(TidalSwell,85,20); //Set RW to 85% speed with 20ms pulse in Tidal Swell Mode
else if (now() % SECS_PER_DAY >= 15 * SECS_PER_HOUR && now() % SECS_PER_DAY < (17 * SECS_PER_HOUR + 0 * SECS_PER_MIN) )
else if (now() % SECS_PER_DAY >= (17 * SECS_PER_HOUR + 0 * SECS_PER_MIN) && now() % SECS_PER_DAY < (18 * SECS_PER_HOUR + 30 * SECS_PER_MIN))
ReefAngel.DCPump.SetMode(NutrientTransport,85,700);//Set WP40 to 90% speed with NutrientTransport Mode
else if (now() % SECS_PER_DAY >= (18 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now() % SECS_PER_DAY < (18 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(Lagoon,85,20);//Set RW8 to 80% speed with pulse in Lagoon Mode
else if (now() % SECS_PER_DAY >= (19 * SECS_PER_HOUR + 0 * SECS_PER_MIN) && now() % SECS_PER_DAY < 20 * SECS_PER_HOUR )
else if (now() % SECS_PER_DAY >= 20 * SECS_PER_HOUR && now() % SECS_PER_DAY < (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(ReefCrest,75,20);//Set RW8 to 70% speed with Lagoon Pulse Mode
else if (now() % SECS_PER_DAY >= (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now() % SECS_PER_DAY < (22 * SECS_PER_HOUR + 35 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(Lagoon,90,20);//Set RW8 to 90% speed with pulse in Lagoon Mode, dossing coral feed.
ReefAngel.DCPump.SetMode(NutrientTransport,40,30);
static unsigned long feeding;
if (now()-feeding<1*SECS_PER_HOUR) {
//Autofeeder
if ( ((hour() == 18)) && (minute() == 58) &&(second() == 30) ) ReefAngel.FeedingModeStart();
//Skimmer off 1.5 hours when coral feeding.
if (now()%SECS_PER_DAY >= (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now()%SECS_PER_DAY < (23 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
ReefAngel.Relay.Off(Skimmer);
static boolean powerOutage=false;
if (!ReefAngel.Relay.IsRelayPresent(MAIN_RELAY)) // Main Relay NOT present
powerOutage=true;
ReefAngel.Relay.Off(Return);
ReefAngel.Relay.Off(None1);
ReefAngel.Relay.Off(Wavepump);
ReefAngel.Relay.Off(ZeovitShake);
ReefAngel.Relay.Off(Heater);
ReefAngel.Relay.Off(Relay_Box2);
ReefAngel.Relay.Off(ATOPump);
if (powerOutage && ReefAngel.Relay.IsRelayPresent(MAIN_RELAY))
LastStart=now();
powerOutage=false;
ReefAngel.Relay.On(Skimmer);
// Turn off Skimmer if Return pump has been shutoff.
if (!ReefAngel.Relay.Status(Return)) {
ReefAngel.Portal( "sesame");
Posted: Tue Dec 30, 2014 8:11 am
by sesame
lnevo wrote:Were you using teraterm or the Serial Monitor inside the Arduino app. Can you post your full code. Can you upload the code again and then monitor again via the serial monitor.
using Arduino Serial monitor. another 10 min. but nothing popup.
may have issue with my laptop?
Posted: Tue Dec 30, 2014 9:14 am
It is weird, because if you can upload codes, you should be able to get it to send data.
To make sure we are in the same page, upload this same above code one more time and right after upload, open Serial Monitor without disconnecting the cable or even touching it at all.
Do you get anything after 10 to 15mins?
If you do not, make sure that "Both NL & CR" is selected on the left side of the baud rate.
On the top part of the window, by the Send button, type "GET / HTTP" and hit enter.
Do you get anything now?
Posted: Tue Dec 30, 2014 9:22 am
Should also add some Serial.println as a test..
Posted: Tue Dec 30, 2014 9:33 am
by sesame
Will have another try
Posted: Tue Dec 30, 2014 9:39 am
Your code looks fine, nothing that would interfere. Just an FYI though, you can't monitor for power outages with the main relay box since the RA will also lose power in that scenario. You can monitor your expansion relay boxes only.
Posted: Wed Dec 31, 2014 7:01 am
by sesame
upload code again, and checked with buildin monitor, nothing happend at "both nl / cr"
type get / http shown message below:
HTTP/1.1 200 OK
Server: ReefAngel
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Connection: close
Content-Type: text/html
Content-Length: 41
<h1>Reef Angel Controller Web Server</h1>
Posted: Wed Dec 31, 2014 8:31 am
ok so I/O is working.. very odd. Did you add a Serial.println as a test?
Posted: Wed Dec 31, 2014 8:50 am
by sesame
lnevo wrote:ok so I/O is working.. very odd. Did you add a Serial.println as a test?
how to, no idea. thank you
Posted: Wed Dec 31, 2014 9:01 am
Add this in your loop:
Serial.println("test");
Posted: Wed Dec 31, 2014 9:11 am
by sesame
lnevo wrote:Add this in your loop:
"test" popup crazy in monitor. is that means it works?
Posted: Wed Dec 31, 2014 9:26 am
Yeah. I would remove your libraries folder and re-install the ReefAngel installer at this point. Serial I/O is working and you can obviously communicate with the wifi module. Something is not right that the portal timer is not working. If a libraries re-install does not help, I would suggest regenerating a new basic code and testing.
Posted: Wed Dec 31, 2014 9:27 am
Yes... You can remove that line now.
There doesn't seem to be any reason why your controller doesn't send data.
Posted: Wed Dec 31, 2014 11:30 am
Jesus!!!!
I spent all morning today trying to figure out why this wasn't working...
Here is the offending line:
The timer 4 is in charge of sending data to the Portal.
It never struck at me that you were using that function. I though that was a repeat dosing schedule for some reason.
We need to change that function to not use timers at all.
This is the same equivalent:
if (hour()==22 && minute()==32 && second()<40)
ReefAngel.Relay.On(ZEO_SP);
ReefAngel.Relay.Off(ZEO_SP);
Try this out and let me know if that works for you.
Posted: Wed Dec 31, 2014 11:46 am
Awesome find! I was looking for it and it was completely hidden there
I thought the DosingPump functions already had that out.. I guess only the Repeat ones have been.
Posted: Wed Dec 31, 2014 7:44 pm
by sesame
Wahoo!!
great new year gifts.
change code as Roberto attached. got some thing from serial port.
GET /status/submitp.aspx?t1=187&t2=223&t3=226&ph=793&id=sesame&em=1&em1=2&rem=1&bid=1&key=&ddns=&af=0&sf=0&atohigh=0&atolow=0&r=205&ron=0&roff=255&r1=4&ron1=0&roff1=255&pwma=90&pwmd=80&pwmao=255&pwmdo=255&pwme0=0&pwme0O=255&pwme1=100&pwme1O=255&pwme2=0&pwme2O=255&pwme3=0&pwme3O=255&pwme4=0&pwme4O=255&pwme5=0&pwme5O=255&dcm=1&dcs=85&dcd=20&dct=30
waiting half an hour to see if any changes from portal.
sorry havent remember to change code this area. should be careful next time.
but im thinking if possible to add more "DosingPumpRepert" function in lib and iOS App as well.
easy to change and adjust by mobile device.
Posted: Wed Dec 31, 2014 9:17 pm
by sesame
portal and banner get back to work.
thank you for your support Roberto, Lee. appreciate and best support i've ever have.
Posted: Thu Jan 01, 2015 7:56 am
Glad it's working now! Happy New Year!
