Coding Third Jebao on Dim Exp
Posted: Fri Jan 02, 2015 11:07 am
Hello all,
I'm trying to figure out how to code my third Jebao on a separate schedule from my other two which are using DCPump on sync and anti-sync. The third pump will be using the expansion channel 2, and im trying to figure out how to put on long pulse and short pulse at different times of day. I can write the if>then to change when i want it on which mode, but have had trouble coding the expansion channel to do what i want it to.
