update, now error in compiling?
Posted: Sun Jan 04, 2015 9:58 pm
by Docstach
Around June I set up a program with 2 DC wavemakers. I used a code on here suggested for an else mode. Today I opened Arduino because I wanted to change my on/off temp for my heater. When I first opened up the program it asked me to update the libraries so I did. When I went to compile the same program I am now using I now get an error? Any suggestions? Thanks, Matt
Error:
Watchdog Timer
Version Menu
Dimming Signal
DC Pump Control (Jebao/Tunze)
2014 Main Screen
Extra Font - Medium Size (8x8 pixels)
Standard Menu
Globals/Globals.cpp.o: In function `ElseMode(unsigned char, unsigned char, unsigned char)':
/Users/Matt/Documents/Arduino/libraries/Globals/Globals.cpp:881: multiple definition of `ElseMode(unsigned char, unsigned char, unsigned char)'
sketch_jun13a_multimode_pump_v9.cpp.o:sketch_jun13a_multimode_pump_v9.cpp:124: first defined here
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.StandardATO( Port1,7200 );
    ReefAngel.StandardLights( Port2,22,0,10,0 );
    ReefAngel.StandardLights( Port3,11,0,22,15 );
    ReefAngel.StandardLights( Port4,12,0,22,0 );
    ReefAngel.StandardHeater( Port7,770,780 );
    if (hour()>=0 && hour()<6)
  ReefAngel.PWM.SetDaylight( ElseMode(30,10,true) ); // Else on sync mode
  ReefAngel.PWM.SetActinic( ElseMode(30,10,false) ); // Else on sync mode
else if (hour()>=6 && hour()<10)
  ReefAngel.PWM.SetDaylight( ElseMode(40,20,true) ); // Else on sync mode
  ReefAngel.PWM.SetActinic( ElseMode(40,20,false) ); // Else on sync mode
else if (hour()>=10 && hour()<13)
  ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
  ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,true) ); //   Nutrient Transport on sync mode
else if (hour()>=13 && hour()<22)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,90,800,true) ); // Short pulse at 80% with 800ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,90,800,true) ); // Short pulse at 80% with 800ms pulse on sync mode
else if (hour()>=22 && hour()<=24)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(40,20,true) ); // reefcrest at 40% hours 22-24 on sync
  ReefAngel.PWM.SetActinic( ReefCrestMode(40,20,true) ); //
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Re: update, now error in compiling?
Posted: Sun Jan 04, 2015 10:02 pm
Remove the entire ElseMode function at the end of your code.
It has been added to the libraries on the latest update.
Posted: Sun Jan 04, 2015 10:06 pm
by Docstach
Great, thanks!!
