Page 1 of 3
Reefology's code
Posted: Mon Jan 05, 2015 4:23 pm
by Reefology
Current code
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
// Define Relay Ports by Name
#define             Box1_Port1
#define skimmer            Box1_Port2
#define actinics           Box1_Port3
#define t5                 Box1_Port4
#define sumplight          Box1_Port5
#define fan                Box1_Port6
#define radions            Box1_Port7
#define returnpump         Box1_Port8
#define cafeed             Box2_Port1 // CaRx Feed Pump
#define co2                Box2_Port2 // Co2 Solenoid
#define carecirc           Box2_Port3 // CaRx Recirculation Pump
#define heaters            Box2_Port4
#define ozone              Box2_Port5
#define              Box2_Port6
#define powerheads         Box2_Port7
#define              Box2_Port8
//DC Power Expansion
#define dosingCa           Box3_Port1
#define dosingVin          Box3_Port2
#define dosingTrace        Box3_Port3
#define dosingMg           Box3_Port4
#define alkdosing          Box3_Port5
#define              Box3_Port6
#define feeder             Box3_Port7
#define              Box3_Port8
// Virtual Relays
#define co2purge           Box4_Port1
#define showcorals         Box4_Port2
#define feednow            Box4_Port3
void SeasonalTemps ()
  static int heatArray[][2] = { {762,768},// default in case of error in month=0 (May)
                    {746,752},//January (winter)
                    {750,756},//February (winter)
                    {754,760},//March (early spring)
                    {758,764},//April (spring)
                    {762,768},//May (spring)
                    {768,774},//June (early summer)
                    {774,780},//July (summer)
                    {772,778},//August (summer)
                    {766,772},//September (early fall)
                    {760,766},//October (fall)
                    {754,760},//November (fall)
                    {750,756} };//December (early winter)
  ReefAngel.StandardHeater( heaters,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
    ReefAngel.Star();
    ReefAngel.AddExtraTempProbes(); // Adds 3 More Temp Probes
    ReefAngel.AddHumidityExpansion();  // Humidity Expansion
    ReefAngel.FeedingModePortsE[0] = Port8Bit;
    ReefAngel.FeedingModePortsE[1] = Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port8Bit;
    ReefAngel.WaterChangePortsE[1] = Port7Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.OverheatShutoffPortsE[1] = Port4Bit;
    ReefAngel.LightsOnPortsE[0] = Port5Bit | Port7Bit;
    // Ports that default on
    ReefAngel.Relay.On( returnpump );// Return
    ReefAngel.Relay.On( powerheads ); // DC power heads on smart bar
    // Ports that default off
    ReefAngel.Relay.Off( heaters ); // Heaters
    ReefAngel.Relay.Off( ozone ); // Ozone
    ReefAngel.Relay.Off( dosingCa ); // Dosing Pump 1
    ReefAngel.Relay.Off( dosingVin ); // Dosing Pump 2
    ReefAngel.Relay.Off( dosingTrace ); // Dosing Pump 3
    ReefAngel.Relay.Off( dosingMg ); // Dosing Pump 4
    ReefAngel.Relay.Off( alkdosing ); // Dosing Pump 5
    SeasonalTemps();
     ReefAngel.StandardLights( actinics,12,50,20,30 ); // Royal blue led strip
    //ReefAngel.StandardLights( t5,13,00,16,00 ); // T5's
    ReefAngel.StandardLights( sumplight,23,30,9,0 ); //Sump light
    ReefAngel.StandardLights( radions,12,45,20,10 ); //Radions
    ReefAngel.StandardLights( co2,12,35,23,30 ); // Co2 Solenoid
    ReefAngel.StandardLights( carecirc,12,30,23,55 ); // CaCo3 Recirculation Pump
    ReefAngel.DosingPumpRepeat( ozone,240,1440,1800 ); // Ozone, on 4am=240mins offset from midnight, 1440=every 1440 mins (once a day), for 30 mins=1800 sec's
     //Virtual Relays
    ReefAngel.Relay.Off( co2purge );// Purge Co2 from Calcium Reactor
    ReefAngel.Relay.Off( Box4_Port2 );
    ReefAngel.Relay.Off( Box4_Port3 );
    ReefAngel.Relay.Off( Box4_Port4 );
    ReefAngel.Relay.Off( Box4_Port5 );
    ReefAngel.Relay.Off( Box4_Port6 );
    ReefAngel.Relay.Off( Box4_Port7 );
    ReefAngel.Relay.Off( Box4_Port8 );//Test Virtual Switch
    // RA* Dimmers
    //ReefAngel.PWM.SetDaylight( PWMSlope( 15,30,20,30,0,50,90,0 ) ); //analog
    if (hour(now())<15)  ReefAngel.PWM.SetActinic( PWMSlope( 12,50,14,59,0,100,10,0 ) ); //analog
    ReefAngel.PWM.SetActinic( PWMSlope( 15,00,20,30,0,90,60,0 ) );
    //ReefAngel.PWM.SetActinic( PWMSlope( 11,30,20,30,0,95,60,0 ) ); //analog
    //ReefAngel.PWM.Daylight2PWMSlope();
    //ReefAngel.PWM.Actinic2PWMSlope();
    //Dimmer Expansion PopBloom RS90
    //Whites
    if (hour(now())<15)  ReefAngel.PWM.SetChannel( 0,PWMSlope( 12,55,14,59,0,100,05,0) );
    ReefAngel.PWM.SetChannel( 0,PWMSlope( 15,00,22,00,0,60,90,0) );
   //Blues
    if (hour(now())<15)  ReefAngel.PWM.SetChannel( 1,PWMSlope( 12,50,14,59,0,100,10,0) );
    ReefAngel.PWM.SetChannel( 1,PWMSlope( 15,00,23,45,0,85,90,0) );
   //Cyan
    if (hour(now())<15)  ReefAngel.PWM.SetChannel( 2,PWMSlope( 12,50,14,59,0,100,10,0) );
    ReefAngel.PWM.SetChannel( 2,PWMSlope( 15,00,23,30,0,85,120,0) );
   //Moon
    ReefAngel.PWM.SetChannel( 3,MoonPhase()*0.35);
    //Fan
    ReefAngel.PWM.SetChannel(4,PWMSlope(00,00,12,00,10,80,90,0 ));
    //ReefAngel.PWM.Channel0PWMSlope();
    //ReefAngel.PWM.Channel1PWMSlope();
    //ReefAngel.PWM.Channel2PWMSlope();
    //ReefAngel.PWM.Channel3PWMSlope();
    //ReefAngel.PWM.Channel5PWMSlope();
    boolean buzzer=false;
    //if ( ReefAngel.isATOTimeOut() ) buzzer=true;
    //if ( ReefAngel.isOverheat() ) buzzer=true;
    if ( ReefAngel.isBusLock() ) buzzer=true;
    // Turn off skimmer if return pump is off or from 9am-7pm
    if (!ReefAngel.Relay.Status(returnpump) || (hour()>=14 && hour()<=21)) { //if return pump is off or from 2pm-8:59pm
    ReefAngel.Relay.Off(skimmer);
    } else {
    ReefAngel.Relay.DelayedOn(skimmer,5); // Delay start skimmer when return pump is back on
    // Turn off skimmer if collection container is full
    if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Override(skimmer,0);
     // CaRx Feed Pump
    if ((hour() == 6 && minute() <=10) || (hour()>=13 && hour()<23) || (hour() == 23 && minute() <45)) ReefAngel.Relay.On(cafeed);//On from 6-6:10am and 1-11:45pm
    else ReefAngel.Relay.Off(cafeed);
    //Dosing Pumps
    ReefAngel.DosingPumpRepeat1( dosingCa );
    ReefAngel.DosingPumpRepeat2( dosingVin );
    ReefAngel.DosingPumpRepeat3( dosingTrace );
  // ALK Dosing
    if (hour() == 12 && minute() == 30 && second() >= 0 && second() <= 50) {
    ReefAngel.Relay.On(alkdosing);
  } else {
    ReefAngel.Relay.Off(alkdosing);
  // Auto Fish feeder
   if (hour() == 13 && minute() == 30 && second() >= 0 && second() <= 13) ReefAngel.Relay.On(feeder);
   else if (hour() == 18 && minute() == 30 && second() >= 0 && second() <= 13) ReefAngel.Relay.On(feeder);
   else ReefAngel.Relay.Off(feeder);
  //Light Canopy Cooling
    if (ReefAngel.Params.Temp[T5_PROBE] >= 825) ReefAngel.Relay.On(fan);
    if (ReefAngel.Params.Temp[T5_PROBE] <= 705) ReefAngel.Relay.Off(fan);
     // Check if the virtual switch is turned on
    if (ReefAngel.Relay.Status(showcorals)) { // if showcorals virtual switch is on
        ReefAngel.Relay.Off( t5 );
        ReefAngel.Relay.On(actinics); // Turn on the actinics
        ReefAngel.Relay.On( sumplight );
        ReefAngel.PWM.SetChannel(0, 05); // Dimming channel 0 to 5%
        ReefAngel.PWM.SetChannel(1, 35); // Dimming channel 1 to 35%
        ReefAngel.PWM.SetChannel(2, 60); // Dimming channel 2 to 60%
        ReefAngel.PWM.SetChannel(3, 70); // Dimming channel 3 to 70%
        ReefAngel.PWM.SetActinic(55); // Dim the actinics to 55%
    ReefAngel.Network.Cloud();
// RA_STRING1=4rBCB5aEN369IDJFYl/ESQ==::NTdkYmJkMzM0ODdmMmE0NA==
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_TEMP1=FishRoom
// RA_LABEL LABEL_TEMP2=Sump
// RA_LABEL LABEL_TEMP3=OverFlow
// RA_LABEL LABEL_TEMP4=LightCanopy
// RA_LABEL LABEL_TEMP5=Cabinet
// RA_LABEL LABEL_TEMP6=NotInUse
// RA_LABEL LABEL_ACTINIC2=Actinic2
// RA_LABEL LABEL_DAYLIGHT2=Daylight2
// RA_LABEL LABEL_PWME0=Whites
// RA_LABEL LABEL_PWME1=Blues
// RA_LABEL LABEL_PWME2=Cyan
// RA_LABEL LABEL_PWME3=MoonLights
// RA_LABEL LABEL_PWME4=Channel4
// RA_LABEL LABEL_PWME5=Channel5
// RA_LABEL LABEL_PORT11=11
// RA_LABEL LABEL_PORT12=Skimmer
// RA_LABEL LABEL_PORT13=BlueLeds
// RA_LABEL LABEL_PORT14=T5's
// RA_LABEL LABEL_PORT15=SumpLight
// RA_LABEL LABEL_PORT16=Fan
// RA_LABEL LABEL_PORT17=Radions
// RA_LABEL LABEL_PORT18=Return
// RA_LABEL LABEL_PORT21=CaFeed
// RA_LABEL LABEL_PORT22=Co2 Sol
// RA_LABEL LABEL_PORT23=CaRecir
// RA_LABEL LABEL_PORT24=Heaters
// RA_LABEL LABEL_PORT25=Ozone
// RA_LABEL LABEL_PORT26=26
// RA_LABEL LABEL_PORT27=PowerHeads
// RA_LABEL LABEL_PORT28=28
// RA_LABEL LABEL_PORT31=DoseCa
// RA_LABEL LABEL_PORT32=DoseVin
// RA_LABEL LABEL_PORT33=DoseTrace
// RA_LABEL LABEL_PORT34=DoseMg
// RA_LABEL LABEL_PORT35=DoseAlk
// RA_LABEL LABEL_PORT36=36
// RA_LABEL LABEL_PORT37=Feeder
// RA_LABEL LABEL_PORT38=38
// RA_LABEL LABEL_PORT41=PurgeCo2
// RA_LABEL LABEL_PORT42=ShowCorals
// RA_LABEL LABEL_PORT43=FeedNow
// RA_LABEL LABEL_PORT44=Virtual
// RA_LABEL LABEL_PORT45=Virtual
// RA_LABEL LABEL_PORT46=Virtual
// RA_LABEL LABEL_PORT47=Virtual
// RA_LABEL LABEL_PORT48=Test
Re: My code
Posted: Mon Jan 05, 2015 4:25 pm
by Reefology
so should i take the jebao port offline? well it isn't working anyway :D
Re: My code
Posted: Mon Jan 05, 2015 4:53 pm
by cosmith71
Just set it to always on, or plug it into a power strip. Let the stock Jebao controller handle the pump, unless you want to use a Jebao cable to control it with the RA.
You also need to remove this line:
ReefAngel.DDNS( "Reefology" ); // Your DDNS is Reefology-tank.myreefangel.com
You already have a DDNS declaration in setup(). That's probably why you're having issues with your phone app.
Re: My code
Posted: Mon Jan 05, 2015 4:58 pm
by Reefology
great Colin, will do. But you might want to note that i didnt manually add it, was done by the wizard.
I also wanted to add password authentication but havent' figured out how, can you help me with that? I'm aware i won't be able to use the iphone app until its supported.
thanks
Re: My code
Posted: Mon Jan 05, 2015 5:48 pm
by cosmith71
Must have been an evil Wizard. Voldemort is my guess. ;)
I don't use the password authentication. Maybe someone else can chime in. I do know you won't be able to use the iPhone app if you enable it.
Re: Reefology's code
Posted: Mon Jan 05, 2015 5:51 pm
Add this in setup
ReefAngel.Network.WifiAuthentication("username:password");
Change username and password for whatever you'd like it to be.
Posted: Mon Jan 05, 2015 6:14 pm
by Reefology
great thanks, i forgot Roberto had already given it to me just couldn't find it.
Posted: Thu Jan 08, 2015 10:53 am
by Reefology
Added this custom code that i copied from anothher user but not getting desired result. Can someone explain each section so i can learn the code and make adjustments going forward please?
FYI, i changed ''if (now()%SECS_PER_DAY==600'' from 0 to 600 hoping to change mode every 10 mins.
static int rmode;
    byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre };
    if (now()%SECS_PER_DAY==600 || changeMode==true) { // Change every 10 mins or if controller rebooted
    rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3600) {
    // Continue NTM for the 60 minutes
    ReefAngel.DCPump.Mode=NutrientTransport;
    } else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Sine;
    ReefAngel.DCPump.Speed=30;
    } else if (InternalMemory.DCPumpMode_read()==11) {
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
Posted: Thu Jan 08, 2015 11:00 am
What desired behavior are you trying to get and what behavior are you seeing instead..
Posted: Thu Jan 08, 2015 12:52 pm
by Reefology
thanks for the quick response. I have a single WP40 and would like to have alternate wave modes that change throughout each day, I'd like a calm mode at night running at 30% or less if possible (but not sure it is), I'd like to override via internal memory if possible and then have it revert back to random after a set time (but not a must have).
I like the way it kicks into night mode and feed mode but it doesnt alternate wave patterns listed in the code its stuck in else mode.
Posted: Thu Jan 08, 2015 1:26 pm
by cosmith71
I think it's this line here.
This tells it to change modes every 24 hours and 10 minutes.
Try changing it to this.
if (now()%600==0 || changeMode==true) {
Edit: Forgot the {
Posted: Thu Jan 08, 2015 2:07 pm
by Reefology
thanks so much, will try that. while we're at it, is there anyway to make the speed random? I assume some of the modes have random speed built in but i dont know which ones so I just selected all of them hoping to get a varying flow.
Thnaks
Posted: Thu Jan 08, 2015 2:08 pm
by cosmith71
Here's some commented code. You will also find this link handy:
http://arduino.cc/en/Reference/HomePage
Look up the different kinds of data types (int, boolean, unsigned long) and also if...else. Also read up on arithmetic, boolean, and comparison operators.
// Declare an integer (a whole number between -32,768 to 32,767) rmode
// and a boolean (false or true, 0 or 1) changeMode which is set to true.
// "static" means only initialize them once.  Otherwise they would be reset
// every time loop loops around.
static int rmode;
// modes[] is an array of bytes (whole numbers between 0 and 255).
byte modes[] = {
// now() is a running tally of seconds since Jan 1, 1970.  It's a big number.
// % is modulo, it returns the remainder from division.  So, if the number of seconds ever
// divided by 600 is 0 (that is, every 600 seconds or 10 minutes) then this is true.
// The || means 'or'.  '==' means 'is equal to'.  So this line says 'if it's been 10 minutes,
// or changeMode is equal to true, then do this stuff in these curly braces.
if (now()%600==0 || changeMode==true) { // Change every 10 mins or if controller rebooted
  changeMode=false;
static unsigned long feeding;  // another variable declaration, type unsigned long
// Difference between '==' and '=':  '==' means 'is equal to' (comparing two things)
// '=' means 'make equal to' as in changing the value of something.  So this line
// says if the menu displayed is equal to FEEDING_MODE, then make the variable 'feeding'
// equal to the number of seconds returned by the function now()
// if right now minus the time feeding was set is less than 3600 (seconds, remember now() returns
// seconds) then do the stuff in the curly braces.
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of the pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get the portal pump duration from memory
  ReefAngel.DCPump.Mode=NutrientTransport;    // Manually set the mode to NutrientTransport
// so if the above 'if' isn't true, do the stuff after 'else'.  If this thing is true, do this stuff, else do other stuff
// If it's been more than 60 minutes since feeding time, check to see if now (in seconds) divided by
// the number of seconds per day (86400 to be exact) returns a remainder of less than 43200 (noon)
// or greater than 79200 (10 PM, 2200) then do some stuff
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of DC Pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get portal duration from memory location
  ReefAngel.DCPump.Mode=Sine;  // Set the mode to Sine
  ReefAngel.DCPump.Speed=30;   // With a speed of 30
// if the above isn't true, check this
  // Custom Mode set on portal and nothing else going on (not feeding time, not night time)
  ReefAngel.DCPump.UseMemory=false;  // Turn off portal control of pumps
  ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read();  // Get the duration
// if none of this stuff was true, default to this
else {
  // Do whatever the portal says to do with the DC Pumps
Posted: Thu Jan 08, 2015 2:09 pm
by cosmith71
You mean the speed at which the pumps run? Some modes like Else do that automatically. Others, like gyre and sine, go up and down in a set pattern.
Posted: Thu Jan 08, 2015 2:30 pm
by Reefology
awesome thank you, the notes are a huge help to me. I'll check out the link as well.
cheers
Posted: Thu Jan 08, 2015 2:41 pm
by Reefology
its still stuck in else mode and doesnt change?!
Posted: Thu Jan 08, 2015 2:44 pm
by cosmith71
Do you have the portal set to custom?
Posted: Thu Jan 08, 2015 2:49 pm
by Reefology
not sure, here is all my code:
    ReefAngel.FeedingModePorts = Port6Bit;
    ReefAngel.WaterChangePorts = Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    // Password Protection username:xxxxxxx password:xxxxxxx
    // ReefAngel.Network.WifiAuthentication("xxxxxx,xxxxxxx");
    ReefAngel.DosingPumpRepeat1( Port1 );
    ReefAngel.DosingPumpRepeat2( Port2 );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.MoonLights( Port5 );
    ReefAngel.WavemakerRandom( Port6,120,1500 );
    static int rmode;
    changeMode=false;
    } else {
    ReefAngel.Portal( "Reefology" );
    ReefAngel.DDNS( "xxxxxxxx" ); // Your DDNS is Reefology-xxxxxxxx.myreefangel.com
Posted: Thu Jan 08, 2015 3:35 pm
by Reefology
ok found custom in the portal. but now im wondering what the speed and duration does? doesnt ''custom'' call the code in the custom area thereby overriding speed and duration? asking because now that ive managed to get the modes to changing every 10 minutes, the speed stays the same?
Posted: Thu Jan 08, 2015 3:56 pm
Speed and duration are pulled from the portal. The speed will report in that section as static but you should see the speed change on the screen.
Posted: Thu Jan 08, 2015 7:56 pm
by Reefology
this is awesome, im in love with my reef angel and what it is capable of...
now that i have my dc pump up and running, I'm going back to something i put on hold, can someone please look at the code i just put up and tell me why i still cant log into the iphone app using my DDNS?
Posted: Thu Jan 08, 2015 10:15 pm
Make sure you enter reefology-ddns.myreefangel.com
Change the ddns to whatever you choose. Make sure it is - and not _
Posted: Fri Jan 09, 2015 10:11 pm
by Reefology
Thanks Roberto but I've checked it too many times to count. Are there other possibilities?
Posted: Fri Jan 09, 2015 10:51 pm
PM me what you are entering. I checked the server and the entries are all there.
I saw 3 entries for you, but they were all same ip address.
Posted: Sun Jan 11, 2015 8:44 pm
by Reefology
pm sent
Posted: Sun Feb 08, 2015 6:15 pm
by Reefology
current code
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
    // Password Protection username:xxxx password:xxxx
    // ReefAngel.Network.WifiAuthentication("xxxx");
    ReefAngel.MoonLights( Port2 );
    ReefAngel.WavemakerRandom1( Port5,120,1500 );
    ReefAngel.WavemakerRandom2( Port6,180,1000 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.DCPump.ActinicChannel = AntiSync; // Now pump will be affected by the portal settings
    // Comment out next 2 lines for single dc pump
    // ReefAngel.DCPump.DaylightChannel = Sync; // Now pump will be affected by the portal settings
    // ReefAngel.DCPump.AntiSyncOffset=100;
  // Wavemaker Koralia night mode
    if (hour()>=22 || hour()<7) ReefAngel.Relay.Off (Port5 );
    if (hour()>=23 || hour()<8) ReefAngel.Relay.Off (Port6 );
  // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    if (now()-feeding<3000) {
    // Continue NutrientTranspot Mode for 45 minutes
    } else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
    ReefAngel.DCPump.Mode=Gyre;
    } else {
    ReefAngel.DDNS("xxxx"); // Your DDNS is Reefology-xxxx.myreefangel.com
Have another dc pump coming and just want to makes sure i'm ready with code.
Posted: Sun Feb 08, 2015 6:17 pm
by Reefology
do i just change this?
Posted: Sun Feb 08, 2015 6:32 pm
by Reefology
and does the antisync offset delay 2nd pump by 100 seconds?
Posted: Sun Feb 08, 2015 7:09 pm
No, it allows the antisync channel to be 100% of what it should be. If you have a strong or weaker pump, you could adjust that pump to compensate.
Posted: Sun Feb 08, 2015 9:52 pm
by Reefology
sorry, i don't understand.
so if i have a Jebao wp40 and a wp25, how would i use the offset?
