RF Expansion
Posted: Mon Jan 05, 2015 6:21 pm
by Lionfan
Ran the wizard with my new RF expansion, and I keep getting an error message.
Heres the message.
Watchdog Timer
Version Menu
RF Expansion Module
Wifi Attachment
2014 Main Screen
Simple Menu
Globals\Globals.cpp.o: In function `PWMParabola(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)':
C:\Users\Tina\Documents\Arduino\libraries\Globals/Globals.cpp:267: undefined reference to `LightsOverride'
Globals\Globals.cpp.o: In function `PWMSlope(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)':
C:\Users\Tina\Documents\Arduino\libraries\Globals/Globals.cpp:229: undefined reference to `LightsOverride'
here's the code im running.
        // Define labels for 2014 LCD screen
  ReefAngel.CustomLabels[0]="Return";
  ReefAngel.CustomLabels[1]="Skimmer";
  ReefAngel.CustomLabels[2]="Heater";
  ReefAngel.CustomLabels[3]="Fan";
  ReefAngel.CustomLabels[4]="ATO";
  ReefAngel.CustomLabels[5]="Powerheads";
  ReefAngel.CustomLabels[6]="Calcium";
  ReefAngel.CustomLabels[7]="Carbonates";
    ReefAngel.FeedingModePorts = Port2Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardFan( Port4 );
    ReefAngel.StandardATO( Port5 );
    ReefAngel.DosingPumpRepeat1( Port7 );
     if (hour()>=18 && hour()<06) ReefAngel.DosingPumpRepeat( Port8,0,60,200 );
    ReefAngel.RF.ChannelWhiteParabola();
    ReefAngel.RF.ChannelRoyalBlueParabola();
    ReefAngel.RF.ChannelRedParabola();
    ReefAngel.RF.ChannelGreenParabola();
    ReefAngel.RF.ChannelBlueSlope();
    ReefAngel.RF.ChannelIntensityParabola();
    ReefAngel.Portal( "lionfan" );
Thanks in advance for help
Re: RF Expansion
Posted: Mon Jan 05, 2015 6:39 pm
It's a bug.
The two functions are dependent on another class.
Add this comment anywhere in your code:
//ReefAngel.PWM.SetChannel
Re: RF Expansion
Posted: Mon Jan 05, 2015 7:00 pm
by Lionfan
rimai wrote:It's a bug.
Thank you. It uplaoded, but now I cant control the radions, and theyre not doing what the schedule said. I put them back in basic mode.
Re: RF Expansion
Posted: Mon Jan 05, 2015 7:13 pm
by Lionfan
The weird thing is the fact that the controller is showing the percentage I choose, its just that the radions are not talking to the expansion.
Re: RF Expansion
Posted: Mon Jan 05, 2015 9:07 pm
by Lionfan
I've done everything I could. Reset the lights, reset the controller, reset my PC. And for some reason, the rf module just can not control the lights.
Re: RF Expansion
Posted: Mon Jan 05, 2015 9:09 pm
Sorry. Another missing keyword.
Add this comment too:
//ReefAngel.RF.SetChannel
Re: RF Expansion
Posted: Tue Jan 06, 2015 6:08 pm
by Lionfan
rimai wrote:Sorry. Another missing keyword.
no luck. after adding the second comment, I can't even see the intensity of the lights on the controller or portal. Controller says its at zero, and the lights are on full blast.
Re: RF Expansion
Posted: Tue Jan 06, 2015 6:12 pm
When it compiles, does it show Radion communication as one of the enabled features?
Re: RF Expansion
Posted: Tue Jan 06, 2015 6:20 pm
by Lionfan
rimai wrote:When it compiles, does it show Radion communication as one of the enabled features?
yes. is it possible that I need to wait till tomorrow before the schedule kicks in?
Re: RF Expansion
Posted: Tue Jan 06, 2015 7:32 pm
No. The most important thing is to put the Radions on basic mode.
Re: RF Expansion
Posted: Tue Jan 06, 2015 8:07 pm
by Lionfan
I did a factory reset, so I assume they are back on basic mode
Re: RF Expansion
Posted: Tue Jan 06, 2015 8:55 pm
by Lionfan
yea, I did a quick double check, the radions are in basic mode. what is the range of the rf attachment?
Re: RF Expansion
Posted: Tue Jan 06, 2015 9:12 pm
A few feet.
As much as the ecotech radio can reach.
Re: RF Expansion
Posted: Wed Jan 07, 2015 8:21 am
by Lionfan
I moved it to about 8" away from the lights.. Still nothing.
Re: RF Expansion
Posted: Wed Jan 07, 2015 2:27 pm
Are you able to control your vortech pumps?
Re: RF Expansion
Posted: Wed Jan 07, 2015 5:17 pm
by Lionfan
My vortech pumps aren't here right now, they were shipped to ecotech for warranty repairs
Re: RF Expansion
Posted: Thu Jan 08, 2015 3:50 pm
by Lionfan
So im stumped on this one
Re: RF Expansion
Posted: Thu Jan 08, 2015 6:26 pm
Just to remove the internal memory messing with it, did you try it with hard coded settings?
Re: RF Expansion
Posted: Thu Jan 08, 2015 8:26 pm
by Lionfan
rimai wrote:Just to remove the internal memory messing with it, did you try it with hard coded settings?
tried, no luck.
Re: RF Expansion
Posted: Thu Jan 08, 2015 8:46 pm
by Lionfan
well, looks like the rf expansion is gonna be disconnected and sold. theres no use if I can't get it to control my lights.. anyone looking for a RF expansion? 75 bucks, shipped.
Re: RF Expansion
Posted: Mon Mar 02, 2015 12:02 am
by alexwbush
If you didn't get it to work, Roberto just released a firmware update that fixed my issue (and maybe yours too)
Re: RF Expansion
Posted: Mon Mar 02, 2015 10:41 am
by Lionfan
Ah, bummer.
I sent my RF module in for credit
Re: RF Expansion
Posted: Mon Mar 02, 2015 11:22 am
Use it for a new RF module :)
Re: RF Expansion
Posted: Mon Mar 02, 2015 7:31 pm
by alexwbush
Concur, this thing works AWESOME!
I setup a "dummy" relay box where I can enable 10k, 14k, 20k, all blue, moonlights only, etc. Working on programming the moonlights tonight.
Re: RF Expansion
Posted: Mon Mar 02, 2015 7:41 pm
Thats a great idea!!! Doing that next. :)
Re: RF Expansion
Posted: Mon Mar 02, 2015 9:00 pm
by alexwbush
Yup yup, should work well when I want to take pictures or show someone what something looks like under different lights. I'll probably use the blues if I want to keep the tank on longer late at night for guests. Who doesn't love the neon blue effect?
Re: RF Expansion
Posted: Wed Mar 04, 2015 9:55 pm
So just a tease of what I'm setting up right now.
#define LED_4to1  Box3_Port1
#define LED_3to1  Box3_Port2
#define LED_2to1  Box3_Port3
#define LED_1to1  Box3_Port4
#define LED_BLUE  Box3_Port5
#define LED_WHITE Box3_Port6
#define LED_MOON  Box3_Port7
#define LED_STORM Box3_Port8
So for each relay I figure I have two buttons that I can trigger. I'm basically going to monitor each port. If it goes on it will set the override dimming value to the preset numbers for "ON" and then reset the port. If I click on "OFF" then it will run a different preset. Effectively giving me 16 macros on relay bar. The ones that are ratios will be blue:white for ON and white:blue for OFF. The color ones will be ON for high and OFF for low. Storm, I'm thinking I can trigger a cloud effect on one and cloud+lightning on the other.
