What to start with?
Posted: Tue Jan 06, 2015 5:40 pm
by JonLachelt
I want an ATO, and since I think I will want a controller in the future (for dimming, and wave control, etc) I'm thinking it makes sense to start with a RA instead of getting a stand-alone ATO system.
So, will I be happy with the RA+ out of the box with its two float switches? Can that make an adequate ATO controller? Or will I really want the MultiChannel Water Level expansion?
Re: What to start with?
Posted: Tue Jan 06, 2015 7:30 pm
You would be fine with float switches to start out and as you get comfortable you can invest in the WL sensor.
You came to a great conclusion
![Smile :)](./images/smilies/icon_e_smile.gif)
a lot more value going this route.
Posted: Wed Jan 07, 2015 4:11 am
by cosmith71
What he said.
Posted: Wed Jan 07, 2015 12:25 pm
by JonLachelt
Thanks so much.
Also, when I connect my WP-25 I assume the power comes fully from the RA (no use for the original power supply). Is that correct?
I'd also like to add an RW-8, will the base controller handle two wave makers, or do I need an expansion?
As an aside... We have a 4', 55g tank (currently just fish, live-rock & sand... but adding corals in the future) . Any opinion on whether I should go with adding the RW-4 or RW-8? I hear the RW pumps are pretty strong and most people are running them at very low power in these smaller tanks.
Posted: Wed Jan 07, 2015 4:13 pm
No the power still comes from the power supply. The only thing you won't need is the controller from the wp-25. If you have a free dimming port you won't need a dimming expansion yet. You'll probably be fine with the rw-4 with the other powerhead and it being a smaller tank. However if you lost the wp-25, not sure it would cover by itself.
Posted: Thu Jan 08, 2015 11:10 am
by JonLachelt
lnevo wrote:No the power still comes from the power supply.
Oh... so does the Jebao/Speedwave Cable connect the 3 elements together (RA controller, Jebao powersupply, wavemaker)?
Thanks for the info on the RW-4/8. I'll probably just go with the 8, and hopefully be able to dial it back.
Posted: Thu Jan 08, 2015 11:20 am
by cosmith71
Yep, the cable connects to the controller, pump, and PS.
The RW's dial back to 20%, vs the old WP's which only went to 30%. I'd go with the 8 on a 55, since you'll want to get a bigger tank sometime in the future.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
