tide sim
Posted: Wed Jan 14, 2015 5:37 am
by james
i want to use the tide library to control my return pump with a arduino nano.
i just don't know how to go about using it in my program.
do i need to include moon also? its a stand alone thing just runs the return pump speed.
thanks
james
Re: tide sim
Posted: Wed Jan 14, 2015 6:04 am
The tide class is a standalone, you don't need moon. It will return a wave that increases and decreases by default twice a day. The main thing it does is change the amplitude of the wave based on the phase of the moon. During new moons and half moon the high and low will be small and during full moon and quarter moon the difference between high and low will be greater depending on your settings..
However I don't think this is wise to use on a return pump. Varying the speeds throughout the day will mess with the level of water in your return chamber and most likely be a pain for your ATO. Also most drains in order to be silent are tuned for a specific flow rate. But it depends on your system. Your free to try it out and see how it works. Let me know what questions you have.
Re: tide sim
Posted: Thu Jan 29, 2015 2:59 pm
by james
i am not getting this, i tried to just do a simple test program what am i doing wrong?
#include <Tide.h>
int pump = 13;
Tide tide;
void setup(){
pinMode (pump,OUTPUT);
tide.Init(50,5,20);
tide.SetWaveLength(12*SECS_PER_HOUR); // This is the default wavelength
tide.CalcSpeed();
pump = CalcSpeed();
here is the errors i get
Arduino: 1.0.6 (Windows 7), Board: "Arduino Nano w/ ATmega328"
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\eightanaloginputs -IC:\Program Files (x86)\Arduino\libraries\Wire -IC:\Users\Owner\Documents\Arduino\libraries\Time -IC:\Users\Owner\Documents\Arduino\libraries\Tide C:\Users\Owner\AppData\Local\Temp\build8955210389605432914.tmp\sketch_jan29e.cpp -o C:\Users\Owner\AppData\Local\Temp\build8955210389605432914.tmp\sketch_jan29e.cpp.o
In file included from sketch_jan29e.ino:3:
C:\Users\Owner\Documents\Arduino\libraries\Tide/Tide.h:5:21: warning: Globals.h: No such file or directory
In file included from sketch_jan29e.ino:6:
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Arduino.h:47:1: warning: "PI" redefined
C:\Users\Owner\Documents\Arduino\libraries\Tide/Tide.h:3:1: warning: this is the location of the previous definition
C:\Users\Owner\Documents\Arduino\libraries\Tide/Tide.h:20: error: 'boolean' does not name a type
C:\Users\Owner\Documents\Arduino\libraries\Tide/Tide.h:21: error: 'boolean' does not name a type
C:\Users\Owner\Documents\Arduino\libraries\Tide/Tide.h:30: error: 'boolean' does not name a type
sketch_jan29e.ino: In function 'void loop()':
sketch_jan29e:19: error: 'class Tide' has no member named 'CalcSpeed'
sketch_jan29e:22: error: 'Calcspeed' was not declared in this scope
without time.h i don't know how that got in there
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\eightanaloginputs -IC:\Program Files (x86)\Arduino\libraries\Wire -IC:\Users\Owner\Documents\Arduino\libraries\Tide C:\Users\Owner\AppData\Local\Temp\build4448538848442249181.tmp\sketch_jan29a.cpp -o C:\Users\Owner\AppData\Local\Temp\build4448538848442249181.tmp\sketch_jan29a.cpp.o
In file included from sketch_jan29a.ino:3:
In file included from sketch_jan29a.ino:6:
sketch_jan29a.ino: In function 'void setup()':
sketch_jan29a:14: error: 'SECS_PER_HOUR' was not declared in this scope
sketch_jan29a.ino: In function 'void loop()':
sketch_jan29a:19: error: 'class Tide' has no member named 'CalcSpeed'
sketch_jan29a:22: error: 'Calcspeed' was not declared in this scope
Re: tide sim
Posted: Thu Jan 29, 2015 5:49 pm
Use the wizard and grab all the standard includes. Globals.h is probably the most important one you are missing.
Re: tide sim
Posted: Thu Jan 29, 2015 7:08 pm
by james
nope that just made a big mess, to big tried to take some stuff out. errors. i don't want to track down all of the problems there must be an easier way.i guess ill try to just go from 0/255 twice a day and move it up an hour everyday
thanks anyway.
Re: tide sim
Posted: Thu Jan 29, 2015 8:30 pm
No just need the includes not all the code. If your able to compile a normal ra code then you could just use the GyreMode or SineMode functions. You could also if you need it really small just copy the SineMode function into your INO
