Bus Lock
Posted: Thu Jan 15, 2015 6:14 am
by maineultraclassic
What would cause a Bus Lock?
It's happened twice now, I open up the app on my phone and the PH and Salinity are both at minimum readings. I scroll over and the Bus Lock says ON. I do a reboot and things go back to normal again.
Any ideas?
Steve
Re: Bus Lock
Posted: Thu Jan 15, 2015 9:27 am
Something in your expansion bus has a problem.
The first thing I would check is the connection. Make sure they are tight and secure.
Also, check for water damage and then try moving to a different port in the hub.
Re: Bus Lock
Posted: Thu Jan 15, 2015 11:57 am
by Sacohen
I had a bus lock error a couple of months ago and it turned out the my expansion bus had a problem.
I replaced it and everything was fine after that.
Re: Bus Lock
Posted: Thu Jan 15, 2015 1:39 pm
Do you have the RF module? There's some updates that were made to the firmware on it that can help if that is causing issues.
Re: Bus Lock
Posted: Thu Jan 15, 2015 2:38 pm
I have the following -
Reef Angel Plus
3 - temp probes
PH probe
Wi-Fi
Expansion Hub
Salinity module
Water level module
So from what you guys are saying, it's something in the expansion hub?
Re: Bus Lock
Posted: Thu Jan 15, 2015 2:45 pm
No, it is anything connected to the bus, but especially the expansion hub, salinity module, wl module and any cables used to connect them together.
I recommend you connect one at a time until you find out the culprit.
Re: Bus Lock
Posted: Fri Jan 16, 2015 5:26 am
I checked all the connections and everything is the same as it's been since I set it up.
I'll keep an eye on it and see if I can find out what's causing it.
