Help with code
Posted: Wed Jan 21, 2015 5:35 pm
by Spotted
Here's my code
    ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
    ReefAngel.LightsOnPortsE[0] = Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 815 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.SingleATO( true,Port1,120,10 );
    ReefAngel.StandardLights( Port2,19,0,7,0 );
    ReefAngel.StandardLights( Port4,10,0,20,0 );
    ReefAngel.StandardLights( Port5,6,0,22,0 );
    ReefAngel.StandardHeater( Port6,780,805 );
    ReefAngel.Relay.DelayedOn( Port7,5 );
    ReefAngel.Relay.DelayedOn( Port8,3 );
    ReefAngel.DosingPumpRepeat( Box1_Port3,0,60,170 );
    ReefAngel.StandardLights( Box1_Port7,13,0,17,0 );
    ReefAngel.StandardLights( Box1_Port8,12,0,18,0 );
    ReefAngel.PWM.SetDaylight( PWMParabola(13,0,16,0,10,80,10) );
    ReefAngel.PWM.SetActinic( PWMSlope(10,0,18,0,15,95,80,15) );
    if ((now()%SECS_PER_DAY==28800)) //if it is 8 AM
    {ReefAngel.FeedingModeStart(); //START FEEDING MODE}
    if ((now()%SECS_PER_DAY==64800)) //if it is 6 PM
    ReefAngel.Portal( "Spotted" );
I'm getting the following errors when I try to compile it. What is wrong with it?
Dimming Signal
Wifi Attachment
Relay Expansion Module
2014 Main Screen
Extra Font - Medium Size (8x8 pixels)
Number of Relay Expansion Modules: 1
Simple Menu
sketch_jan21a.cpp: In function 'void loop()':
sketch_jan21a:124: error: a function-definition is not allowed here before '{' token
sketch_jan21a:158: error: a function-definition is not allowed here before '{' token
sketch_jan21a:190: error: expected `}' at end of input
Binary sketch size: 56,450 bytes (of a 258,048 byte maximum)
Thanks Guys!!
:cry:
Re: Help with code
Posted: Wed Jan 21, 2015 6:30 pm
by Sacohen
There may be more reasons, but from what I see you have the following in two places...
First where it should be at the very beginning before ////// Place global variable code below here
The 2nd time is after ////// Place your custom code below here.
Remove it from after ////// Place your custom code below here.
Re: Help with code
Posted: Wed Jan 21, 2015 6:36 pm
by Sacohen
I looked at it more and you definitely had a bunch of items duplicated.
Try this code.
It compiled for me just fine.
Re: Help with code
Posted: Wed Jan 21, 2015 10:00 pm
by Spotted
I'm sorry, this is the code that should have gotten posted the first time.
What i am trying to do is to get my RA to start feed mode automatically at 8 AM and 6 PM.
Re: Help with code
Posted: Thu Jan 22, 2015 6:27 am
by cosmith71
This should do it.
    if(hour()==8 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();  // Feeding mode at 0800
    if(hour()==18 && minute()==0 && second()==0) ReefAngel.FeedingModeStart(); // Feeding mode at 1800
Re: Help with code
Posted: Thu Jan 22, 2015 6:32 am
by cosmith71
Your original code would work also, but you put the } after the // comment. Everything on the line after // gets ignored.
Should be:
    {ReefAngel.FeedingModeStart();} //START FEEDING MODE
