Code for 2 Jebao wavemakers
Posted: Sat Jan 24, 2015 3:01 pm
by lion-clown
I just my second cable for a Jebao wave-maker and want to add the second one on the opposite side of the tank. I know it is on this site somewhere but just can't seem to find it. What code do I use?
Also is there a list of all the different types of wave functions for these wave-makers?
Re: Code for 2 Jebao wavemakers
Posted: Sat Jan 24, 2015 4:43 pm
by cosmith71
Post your code and we can help. Are you using the actinic and daylight dimming ports?
Posted: Sat Jan 24, 2015 4:56 pm
by lion-clown
I think this is the one I'm using. My last computer crashed and I haven't changed the code since but I'm trying to get back into it and change up the code.
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port4Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.LightsOnPortsE[0] = Port2Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit;
// Ports turned off when Leak is detected
ReefAngel.LeakShutoffPorts = 0;
ReefAngel.LeakShutoffPortsE[0] = Port3Bit | Port4Bit;
ReefAngel.StandardLights( Port1,10,30,22,0 );
ReefAngel.StandardLights( Port2,10,30,22,0 );
ReefAngel.StandardLights( Port3,10,0,22,30 );
ReefAngel.StandardLights( Port4,10,0,22,30 );
ReefAngel.StandardHeater( Port5,787,792 );
ReefAngel.StandardLights( Port7,10,0,23,0 );
ReefAngel.StandardFan( Box1_Port1,795,798 );
ReefAngel.StandardLights( Box1_Port2,22,0,10,30 );
ReefAngel.WavemakerRandom( Box1_Port5,55,100 );
ReefAngel.StandardFan( Box1_Port7,795,799 );
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
ReefAngel.Portal( "lion-clown" );
Posted: Sat Jan 24, 2015 5:03 pm
by cosmith71
You could do this.
Do you have the WiFi module? It's easy to set up so you can change modes on the Portal and see what they're like. I'm not sure a master list of modes exists, but it certainly needs to.
Posted: Sat Jan 24, 2015 5:09 pm
by lion-clown
Yeah I have the WIFI but what do you mean by change modes on the portal?
Do you know some different ones I could try? I'm trying to make it more of a wave.
Posted: Sat Jan 24, 2015 5:14 pm
by lion-clown
Do I want to sync it or have it opposite of the other one so that it doesn't clash?
Posted: Sat Jan 24, 2015 5:19 pm
by cosmith71
Try this code:
If you go onto the Portal, click on "Internal Memory" and "DC Pump" and you'll see the available modes.
by cosmith71
Want one Sync and one AntiSync so they are complimentary.
Posted: Sat Jan 24, 2015 10:09 pm
by lion-clown
What does this line/#s control:
And what does this line/#s control:
ReefAngel.DCPump.SetMode( Sine,35,12 );
Posted: Sun Jan 25, 2015 8:12 am
by cosmith71
That's the old wavemaker function for use with simple powerheads. It basically just switches the outlet on and off like a timer. Don't use it with the Jebaos.
That sets the pumps to Sine mode (basically a sine wave) with a top speed of 35 and a duration of 12 seconds. The bottom speed is 30 by default (WP's don't work well under 30).
