Jebao DC vs Jebao DCT
Posted: Mon Jan 26, 2015 5:14 pm
by rrodriguess
hi there
Does anyone knows if its possible to control the Jebao DCT 6000 the same way we control the DC version? Its important to me since I have to import them and it is quite expensive.
Any thoughts or experience?
Best regards
Rafa
Re: Jebao DC vs Jebao DCT
Posted: Wed Jan 28, 2015 11:54 am
by Sacohen
I haven't heard much about them.
I would think that connection would be the same as the Wavemakers and the DC return pumps, but who knows.
I did find this one image that seems to have the same 3 prong water tight connection that the other Jebao devices have been using.
I'm not sure if it's reversed or not.
http://www.saltwateraquarium.com/jebao- ... model.html
I did find this on manhattanreefs.com by maddhugan
http://www.manhattanreefs.com/forum/gen ... ost1569499
DC can be controlled by Neptune Apex controller (after you buy the Apex to Jebao box for $39 from fishstreet.com), But the pump DCT IS NOT CONTROLLABLE BY NEPTUNE APEX CONTROLLER.
DC has 6 speed step levels but the DCT has 10 speed step levels.
If the Apex can't control it I don't think the Reef Angel will either.
Posted: Wed Jan 28, 2015 5:27 pm
by Ismaclst
I just bought the Jebao DCT 6000 hoping to control it with the reef angel. I wish I would have seen this post before buying it. Hopefully someone else can chime in on this to see if the reef angel can control it.
Posted: Wed Jan 28, 2015 5:34 pm
by Sacohen
The cables look the same as the DC6000 or the wave pumps, but it looks like the pump has a female connection where the DC pumps and the wave pumps have a male connection.
Posted: Wed Jan 28, 2015 5:39 pm
by Ismaclst
Yeah, mine has a female connection on the pump side. If that is the only problem, couldn't i just cut the male end off the Jebao controller and solder that on the pump side? I could sacrifice the Jebao controller since I would control it through the reef angel.
Posted: Wed Jan 28, 2015 5:41 pm
by Sacohen
That should work.
I've never tried it though.
Posted: Wed Jan 28, 2015 5:44 pm
by Ismaclst
Are you running a Jebao DC return pump? I was just wondering if you did to see if you ran into any issues with it.
Posted: Wed Jan 28, 2015 5:51 pm
by Sacohen
I'm running a DC-6000 on ny 55 for about 5 months now and have had no problems.
I'm going to put a DC-12000 on my 90 in a little bit.
Posted: Wed Jan 28, 2015 5:58 pm
by Ismaclst
Ok, just been hearing about a lot of issues with the Jebao DC pumps.
Posted: Wed Jan 28, 2015 6:54 pm
by cosmith71
I've had my DC-9000 for several months with no problems. I should probably clean it soon. :D
