Wifi setup
Ismaclst
Wifi setup
I started to set up my Wifi today. I went through the steps to configure it. After I finished the IP address that it was suppose to give me, was all 0'S and the port was 2000. I didn't have the blue blinking light, so I assume it was configured right. Did I miss something?
Re: Wifi setup
Some routers may take more than usual to provide the ip address, which may result in you seeing 0s.
If it is not blinking blue, it means it is connected.
