multi water level channel 2 issues
Posted: Sun Feb 08, 2015 11:02 am
by Ademster
Channel two of my multi water level expansion doesn't hold its calibration. this is in my ato container... I use it to control a solenoid valve to turn on and off my rodi. it keeps dropping. My water level in the ato is 90% reef angel sees it as 68% which obviously is correct. I have calibrated it 5 times and it still drops.
any ideas?
channel 1 which is in my sump is accurate
Re: multi water level channel 2 issues
Posted: Sun Feb 08, 2015 5:00 pm
It's leaking air somewhere.
Posted: Mon Apr 04, 2016 8:15 am
by WIReefer83
I have a similar issue, but it leaks air over a few weeks. How are people fixing this? Silicone around the tube where it enters the orange cap? Hose clamp around the tube where it connects to the multi-level RA expansion?
Posted: Mon Apr 04, 2016 1:30 pm
by Ismaclst
I used PVC glue around the 1/4" tube and a layer around the other joints for safe measure.
