Temp keeps getting override
Posted: Mon Feb 16, 2015 2:04 pm
by Lionfan
Hey guys, im sure this is something stupid I'm missing. Why does my Reef Angel keep over riding the temp I give it? It does well for about a day and then it just shuts the heater off. and the temp slowly drops to about 72. I have it set on 80, and I am using internal code.
[quote]
       ReefAngel.CustomLabels[0]="Return";
       ReefAngel.CustomLabels[1]="Skimmer";
       ReefAngel.CustomLabels[2]="Heater";
       ReefAngel.CustomLabels[3]="Fan";
       ReefAngel.CustomLabels[4]="ATO";
       ReefAngel.CustomLabels[5]="Powerheads";
       ReefAngel.CustomLabels[6]="Calcium";
       ReefAngel.CustomLabels[7]="Carbonate";
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardFan( Port4 );
    ReefAngel.SingleATOLow( Port5 );
    if (hour()>=06 && hour()<20)ReefAngel.DosingPumpRepeat1( Port7 );
    if (hour()>=20 || hour()<06); ReefAngel.DosingPumpRepeat( Port8,0,60,60 );
    ReefAngel.Portal( "lionfan" );
[/quote]
Re: Temp keeps getting override
Posted: Mon Feb 16, 2015 2:05 pm
by Lionfan
ignore the "quote" in the code
Can you screenshot the values you have set in the portal? Also the value of your temp probe.
Posted: Mon Feb 16, 2015 2:19 pm
by Lionfan
lnevo wrote:Can you screenshot the values you have set in the portal? Also the value of your temp probe.
well, because of the type of router I have (i can only use Verizon hotspot where Im at) my reef angel can't communicate with the portal. So, its just code I upload with the wizard, and whatever I change with the app.
Posted: Mon Feb 16, 2015 2:29 pm
Take screenshots from the app then. Since your using internal memory we can't troubleshoot without seeing your current value
