Analog cable problem with Tunze pumps
Posted: Sun Mar 15, 2015 6:45 pm
I ran in to a weird issue today after I unplugged everything and plugged it back in. Basically my Tunze pumps aren't working correctly with the Tunze cables plugged in. If I unplug the cable the pumps work fine. As soon as I plug them in they don't work as expected.
If I set the pump speed to 100 the pumps work. Anything under 100 and they pulse very quickly. At 50 or below the pumps don't run at all. I checked all the connectors for salt creep and they seem ok. I opened up the relay box to inspect the inside and everything looks fine. I used a multimeter on the cables and the voltage on the cable seems right and isn't pulsing, at least not that I could tell.
I ran the Reef Angel Wizard and uploaded generic code and it does the same thing. I also tried different pump modes and the same thing happens on all modes.
I am not sure what else I should be doing here. I find it odd that both pumps are doing the same exact thing Any help would be appreciated!
