Any other alternative solution to my heater interface is welcome
ATO low/high as output.
billw
I have a 1300 watt heater (3 Finnex elements and a Ranco controller) in my system that I plan on interfacing to the Reef Angel with a relay (http://www.powerswitchtail.com/Pages/default.aspx) driven with either of the ATO outputs. What is the drive capability of these outputs?
billw
Re: ATO low/high as output.
Thanks, Roberto!rimai wrote:Yeap, you can connect straight up into the ATO port
