Temp probe 3pin Connector
Posted: Mon Apr 06, 2015 7:49 am
by ganjero
Is the an easy way to fix/replace the Temp probe 3pin Connector? I just had a second one failed, the cable just came out of the connector after installing the RA in my new house. I am a very careful person, and after having one failed before I handle these connector very carefully.
Re: Temp probe 3pin Connector
Posted: Mon Apr 06, 2015 9:26 am
If the wire came out, you can re-patch it or you can solder it to the connector.
Posted: Mon Apr 06, 2015 10:20 am
by ganjero
What do you mean by repatch it? the cable came out but how do I get the metal pieces out?
Posted: Mon Apr 06, 2015 11:28 am
You can buy those on your local electronics store or you can try pulling them out with a tweezers.
Posted: Mon Apr 06, 2015 2:00 pm
by cosmith71
You can also use 3 pin computer fan connectors to replace them. Just make sure you go by pin position and not wire color when you do.
Posted: Mon Apr 06, 2015 2:27 pm
by ganjero
Thank you
