How have folks mounting their RA hardware?
Posted: Sat Apr 11, 2015 4:29 am
by AlanM
I have a sheet of plywood that I used to have my Apex attached to since every bit of that hardware comes with mounting holes.
So far with the RA Plus, Bluetooth attachment, Wifi attachment nothing works. I tried double-stick industrial velcro (falls off) and gorilla tape and, strangely, reef epoxy with a screw through it. Everything falls off like it has its own extra gravity field pulling it inexorably toward the floor.
What has anyone else done to mount their RA hardware? I thought about unscrewing the head unit from the case, dremeling in a keyhole tab, and putting it back together so I could slip it over a screw...
Re: How have folks mounting their RA hardware?
Posted: Sat Apr 11, 2015 1:59 pm
I took it apart and drilled holes in the back plate. I then screwed that panel into a single narrow wood strip. I reattached the case and attached the strip to a wood panel.
Sent from my Moto X
Posted: Sat Apr 11, 2015 5:33 pm
by Ismaclst
On my old RA I bought some magnets that came with a metal holder with a hole through the center. I drilled holes in the back cover of the RA and used flat head machine screws with nuts to hold the magnets to the cover. I had a metal plate that I screwed to the stand so I could remove the RA easily whenever I needed to. Here is a link to basically what I bought.
http://www.amazon.com/Master-Magnetics- ... +for+doors
Posted: Sat Apr 11, 2015 5:36 pm
by Ismaclst
Forgot to mention that I also used flat head wood screws for the metal plate so they wouldn't interfere with the magnets on the RA.
Posted: Sat Apr 11, 2015 6:18 pm
by Sacohen
I'm using heavy duty velcro.
With the head unit the part that was attached to the plywood cabinet kept coming off so I stapled that to the plywood.
Now everything is fine.
I haven't had issues with the WiFi and Bluetooth modules. They stay up fine with just the velcro.
Posted: Mon Apr 13, 2015 11:16 am
by 89delta
I use Velcro as well
Posted: Mon Apr 13, 2015 6:30 pm
by cosmith71
Ditto on the Velcro. Staples where needed to reinforce the bond to the stand.
Posted: Mon Apr 13, 2015 7:39 pm
by AlanM
Bizarre. The velcro just peels off the back of my head unit but sticks to the wood.
Posted: Tue Apr 14, 2015 6:44 pm
by skehole
I use Velcro for every single part of my RA setup, even the relay box.
Posted: Wed Apr 15, 2015 2:59 am
by cosmith71
AlanM wrote:Bizarre. The velcro just peels off the back of my head unit but sticks to the wood.
That is strange. Normally it's the opposite.
Posted: Wed Apr 15, 2015 6:59 pm
by skehole
Maybe try cleaning the back of the head unit with acetone or rubbing alcohol before applying the Velcro.
