Water Level Expansion: Pipe length
Posted: Mon Apr 13, 2015 10:49 pm
by paperdesk
I just got a used water level expansion, The instructions indicate that one should use pvc, but don't say how long it should be. The unit came with about 5 inches of clear 1/2" plastic tubing attached. Is there any reason I should replace it, lengthen or shorten it?
Re: Water Level Expansion: Pipe length
Posted: Tue Apr 14, 2015 1:48 am
by cosmith71
I don't think the length really matters, up to a point (few feet?). Just use whatever length fits your application.
Were they using the 1/2" tubing instead of PVC? I wouldn't think it would matter.
Posted: Tue Apr 14, 2015 6:56 am
by paperdesk
Yep, 1/2" tubing instead of pvc. It's glued on, so hopefully it will work as is. I'll give it a try. Thanks for the reply!
Posted: Tue Apr 14, 2015 9:31 am
by Sacohen
9" PVC is what comes with the unit, but you can use what ever length you need up to about 15 inches then there is some code that you need to add for longer pipe to work properly.
Check this thread.
http://forum.reefangel.com/viewtopic.ph ... ater+Level
rimai wrote:I still have not had the time to test it, but by looking at the libraries, you can try changing the gain.
Line 55 of WaterLevel.cpp
Change this:
To this:
Let me know if this helps.
Posted: Tue Apr 14, 2015 10:03 am
by paperdesk
Thanks for the post, I did a search, but I never bumped into that thread! Very helpful.
Ted
Posted: Tue Apr 14, 2015 10:22 am
by Sacohen
No Problem.
The only reason I know about it is because I'm going to be putting a pipe top to bottom in a 20 gallon Brute Trash can.
About a 20" pipe.
I think it's titled "Water Level's Limitation".
Posted: Tue Apr 14, 2015 10:53 am
by paperdesk
So, if I understand correctly, the idea is you want to place your sensor at the high water mark, and the pipe will go all the way to the bottom of the container.
Posted: Tue Apr 14, 2015 10:55 am
Depends on what you are trying to accomplish.
My sump is like that, but the overflow is not. I just want to measure to top end of the overflow, so the pipe never reached the bottom.
Posted: Tue Apr 14, 2015 10:59 am
by paperdesk
When I was looking around for info on how to set up the adapter/pipe assembly I saw a photo of your overflow setup. Very cool idea!
Posted: Tue Apr 14, 2015 11:35 am
by Sacohen
paperdesk wrote:So, if I understand correctly, the idea is you want to place your sensor at the high water mark, and the pipe will go all the way to the bottom of the container.
I'm going to measure full (100%) and empty (0%) in my Brute Trash can.
My RO/DI unit will automatically turn on when level is reaches 0% and turn off when it reached the 100% mark.
Posted: Tue Apr 14, 2015 12:19 pm
by paperdesk
Great idea! Now I just need a half dozen of these things!
How do you connect to Reef Angel Controller? Do you use a long bus cable?
Posted: Tue Apr 14, 2015 12:35 pm
by Sacohen
1/2 dozen of the Water Level sensors?
Roberto developed a multi Water level senor that has 4 units in it, so that plus the original single unit will give you 5.
That is the max you can have I believe.
I have the units mounted in my stand with all my other equipment and I'm going to use long tubing to the unit to the PVC tube.
Posted: Tue Apr 14, 2015 12:37 pm
by paperdesk
Ah, I didn't know you could extend the 1/4" tubing. Any idea how long it can be?
Posted: Tue Apr 14, 2015 12:57 pm
by Sacohen
I haven't tried it yet. I'm looking at about 20'.
I already extended 1 to 10' to reach the 10 gallon ATO tank I have set up now.
