reef angel for reptile cage
Posted: Tue Apr 14, 2015 10:39 pm
by theking2a
Hi
would like to use a reef angel in my reptile cages
could the reef angel do the following thing or do I need a plus
3 temp probes
control 3 misters
control actuator
I know I will need a Reef Angel I/o Expansion
my plans when its warm actuator will lift the roof off
and when it get very hot the misters will go on
I have 3 cage in 1 so I need 3 temp probes and 3 misters
would think is will
work
thanks
Matthew
Re: reef angel for reptile cage
Posted: Wed Apr 15, 2015 3:03 am
by cosmith71
RA+. You probably could use a standard RA, but the memory is limited and you'd be limited to old libraries. It would be fairly frustrating in the long run.
Why are you thinking you'd need the I/O expansion?
Posted: Wed Apr 15, 2015 4:15 am
by theking2a
I thought I need a I/O box to connect the switch to turn on the mister and actuator
Do you think there is a better solution
thanks
Matthew
Posted: Wed Apr 15, 2015 5:52 pm
by cosmith71
You could just plug their power supplies into the relay box and turn on the appropriate relays when temps are reached.
Posted: Fri Apr 17, 2015 5:50 am
by Smotz
theking2a wrote:Hi
3 temp probes
control 3 misters
control actuator
would think is will
work
thanks
Matthew
was thinking of doing this same thing.
Posted: Sat Apr 18, 2015 7:40 pm
by theking2a
Hi
I have been researching actuator
the one that I want to use, use a switch to raise the actuator and another switch to lower the actuator
That's they I thought I need a I/O to do the switching can the reef angel to this
thanks
Matthew
Posted: Tue Apr 21, 2015 6:46 am
by cosmith71
Can you post a link to the actuator?
