DCPUMP Class Settings
Posted: Sat Apr 25, 2015 10:58 am
Is there a post somewhere that shows how to program each wave pattern with the new DCPUMP class?
Below shows how the globals.h file has it - Do I code it as such? The wizard codes it differently.
//Wave Patterns
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
byte GyreMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync);
byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync);
byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync);
byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset);
byte ElseMode(byte midPoint, byte offset, boolean waveSync);
