Wifi Attachment Issue & Question
Posted: Sun Jan 01, 2012 10:36 am
Using the wifi graphical utility.
After inputting my settings I choose "Save Settings" and the module displays a slow green blinking light. However, after clicking "view wifi settings" the green light changes to a fast blinking light and it displays:
Another question. Following along with the wifi attachment manual under "Using the Default Web Server" it says "Let's load a simple code to accept web connections." I tried to verify just that piece of code and run into the error 'Class ReefAngelClass' has no member named 'StandardGUI'.
Here's the upper and lower sections:
CMD
get ip
IF=UP
DHCP=ON
IP=0.0.0.0:2000
NM=0.0.0.0
GW=0.0.0.0
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1460
FLAGS=0x7
BACKUP=0.0.0.0
<2.19> get w
SSID=2WIRE994
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=0
Passphrase=k7emk7usakc7ile
<2.19> get u
Baudrate=57600
Flow=0x0
Mode=0x2Another question. Following along with the wifi attachment manual under "Using the Default Web Server" it says "Let's load a simple code to accept web connections." I tried to verify just that piece of code and run into the error 'Class ReefAngelClass' has no member named 'StandardGUI'.
#include <EEPROM.h>
#include <NokiaLCD.h>
ReefAngel.Init();
ReefAngel.StandardGUI();
}Code: Select all
In file included from sketch_jan01a.cpp:7:
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:27:31: error: ReefAngel_Globals.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:28:66: error: ReefAngel_EEPROM.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:30:32: error: ReefAngel_NokiaLCD.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:31:27: error: ReefAngel_ATO.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:32:32: error: ReefAngel_Joystick.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:33:27: error: ReefAngel_LED.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:34:34: error: ReefAngel_TempSensor.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:35:29: error: ReefAngel_Relay.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:36:27: error: ReefAngel_PWM.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:37:29: error: ReefAngel_Timer.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:38:30: error: ReefAngel_Memory.h: No such file or directory
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:76: error: 'ReefAngel_NokiaLCD' does not name a type
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:77: error: 'ReefAngel_JoystickClass' does not name a type
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:78: error: 'ReefAngel_LEDClass' does not name a type
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:80: error: 'ReefAngel_ATOHighClass' does not name a type
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:81: error: 'ReefAngel_ATOLowClass' does not name a type
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:82: error: 'ReefAngel_TempSensorClass' does not name a type
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:83: error: 'ReefAngel_RelayClass' does not name a type
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:105: error: 'ReefAngel_TimerClass' does not name a type
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:236: error: 'Total_Menus' was not declared in this scope
C:\Users\McDaniels\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:237: error: 'Total_Menus' was not declared in this scope
sketch_jan01a.cpp: In function 'void loop()':
sketch_jan01a:13: error: 'class ReefAngelClass' has no member named 'StandardGUI'
