Can't upload any code :(
Posted: Tue May 19, 2015 6:01 am
by Junseld
I get the same error message every time I try to upload code. This is the error I get with trying to upload the initial internal memory:
Copyright (c) 2000-2005 Brian Dean,bdmicro/
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done. Thank you.
Re: Can't upload any code :(
Posted: Tue May 19, 2015 6:06 am
do you have a standard ra or ra plus?
if you don't know, then you can try the opposite one you selected in the wizard.
also, make sure the cable is connected to your controller before you try to upload. i know these are basic suggestions but can be overlooked.
Posted: Tue May 19, 2015 5:29 pm
by Junseld
Binder, thank you for your reply and suggestions. I have already tried both troubleshooting steps but it still will not upload. Please share any other suggestions and thanks again.
Posted: Tue May 19, 2015 5:32 pm
Have you been able to upload any code in the past?
Posted: Wed May 20, 2015 8:21 am
by Junseld
I bought it used and have never seen it work. The version is v1.1.0 Wifi WDT 1.
Posted: Wed May 20, 2015 8:49 am
by Junseld
When I try to restore preloaded code I get the following error message:
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 34,520 bytes (of a 30,720 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1844)
at processing.app.Sketch.build(Sketch.java:1775)
at processing.app.Sketch.exportApplet(Sketch.java:1797)
at processing.app.Sketch.exportApplet(Sketch.java:1783)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2357)
at java.lang.Thread.run(Thread.java:619)
Posted: Wed May 20, 2015 9:02 am
Yes, but you still need to find out if it is a standard RA or a RA+.
This is the first step.
Ask the person you bought it from or open the head unit to check the board revision.
Posted: Wed May 20, 2015 9:57 am
by Junseld
I bought it from a LFS and I have no idea who he ordered it from. I am going to open it it right now. What should I look for? By the way, thanks for helping me.
Posted: Wed May 20, 2015 10:13 am
by Junseld
It says Reef Angel Main Unit 6.1 and there are three jumpers on the board to the right of the knob. A black jumper to the far left and the other two are white jumpers.
Posted: Wed May 20, 2015 8:51 pm
That's a standard RA and you will have a bit of a trouble fitting most codes without stripping it down to the bare minimum.
Make sure the serial port is correct and choose "Reef Angel w/ optiboot" as the option on Boards menu.
Posted: Thu May 21, 2015 6:23 am
by Junseld
I tried a usb port that I didn't think of using before and I was able to upload the code that I made from the wizard. I got error messages, probably due to the fact that it had to strip down the code to get it to fit, but everything is working perfectly now. How much would it cost to upgrade to a RA+ board? Thanks again for your help.
Posted: Thu May 21, 2015 7:47 am
All you need is the RA+ board upgrade in the webstore :)
It's pretty simple to swap.
