Expansion Woes
Posted: Wed May 20, 2015 10:08 am
I’m having expansion woes! I’m ready to admit that need some serious help!
I’ve been using a dimming expansion for quite a while, but recently I came into a bunch of used equipment that was taken from a working system. However, I have been having a bit of trouble, and I don’t know whether to blame the “new” equipment or something else.
What I’ve just added (in addition to the dimming expansion):
Expansion hub
Relay Expansion
Salinity Expansion
Single Water Level Expansion
After adding the above expansions, I noticed that my lights would occasionally blink or go off, even if the dimming expansion were the only thing connected to the expansion hub. Also the salinity and water level expansions would not give stable readings. I was advised to replace the expansion hub, and that seemed to work well.
However, I still seem to be having issues:
1. The salinity reading is stable now when doing calibration, but it slowly drops over time.
2. This morning I had an ato timeout, and the water level readout currently says 0% when it’s actually at more than 100%.
3. When I connect the relay expansion and plug my LED’s into them (2 Evergrow d120’s), my lights occasionally blink off for a moment and back on. I can hear the relay’s click. When I plug them into a power strip not controlled by the RA then they don’t blink off, though my wife said some channels did occasionally go on/off for extended periods yesterday.
Occasionally over the last year I have had seemingly random low ph readings that trigger a warning, but jump right back to normal again. Could this be caused by stray voltage? I checked for that once and didn’t find any, but maybe I should check again.
I’m not sure what to do to troubleshoot things. I’ve tried plugging everything in one expansion at a time, and they seem to behave about the same regardless of what is/isn’t plugged in.
Ted
Expansion hub
Relay Expansion
Salinity Expansion
Ted
