No Comm to Portal
Posted: Wed May 27, 2015 11:48 am
by Lionfan
So,
I finally was able to get an internet provider that allowed me to port forward.
I have access to my controller with reeftronics, the U-app, the Reef Angel Status app.
But, the controller is NOT talking to the portal.
I would rather use the portal, than use reeftronics.
Any help?
I did a factory reset on both the controller and the wifi attachment.
Re: No Comm to Portal
Posted: Wed May 27, 2015 11:52 am
Make sure you have ReefAngel.Portal("Lionfan") line in your code.
If it is already there, are you familiar with Tera term or putty to dump the settings of the WiFi attachment?
Posted: Wed May 27, 2015 11:57 am
by Lionfan
the code is correct, and not at all familiar with the tera term or putty..
Posted: Wed May 27, 2015 12:00 pm
OK, let's try updating the settings then.
Follow instructions here :
Posted: Wed May 27, 2015 12:02 pm
by Lionfan
will do once i get home!
I was reading that earlier, and had a feeling thats what i needed to do.
I'll also check my code to make sure "Lionfan" is correct
there might be a chance it's not capitalized right or something
Posted: Wed May 27, 2015 4:23 pm
by Lionfan
i did both.. Still no comm to portal
Posted: Wed May 27, 2015 5:20 pm
Can you post your entire code?
Also, connect the usb programming cable into RA and open serial monitor on tools menu and make sure it is set to baud 57600.
Wait 5 to 10 minutes and post what you see in the window.
Posted: Wed May 27, 2015 5:45 pm
by Lionfan
rimai wrote:Can you post your entire code?
ReefAngel.CustomLabels[0]="50 Gallon Return";
ReefAngel.CustomLabels[1]="240 Gallon Return";
ReefAngel.CustomLabels[2]="Heater";
ReefAngel.CustomLabels[3]="Fan";
ReefAngel.CustomLabels[4]="Refugium Light";
ReefAngel.CustomLabels[5]="Skimmer";
ReefAngel.CustomLabels[6]="Calcium";
ReefAngel.CustomLabels[7]="Carbonates";
ReefAngel.CustomLabels[8]="ATO";
ReefAngel.CustomLabels[9]="Daylights";
ReefAngel.CustomLabels[10]="Actnics";
ReefAngel.CustomLabels[11]="Moonlights";
ReefAngel.CustomLabels[12]="Reactors";
ReefAngel.CustomLabels[13]="Open";
ReefAngel.CustomLabels[14]="Powerhead";
ReefAngel.CustomLabels[15]="Powerhead";
ReefAngel.FeedingModePorts = Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port5Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardFan( Port4 );
ReefAngel.MoonLights( Port5 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.SingleATOLow( Box1_Port1 );
ReefAngel.Portal( "Lionfan" );
Posted: Wed May 27, 2015 5:46 pm
by Lionfan
waiting on the serial monitor
Posted: Wed May 27, 2015 5:54 pm
by Lionfan
Lionfan wrote:waiting on the serial monitor
Here it is
üGET /status/submitp.aspx?t1=784&t2=784&t3=739&ph=1057&id=Lionfan&em=8&em1=2&rem=1&bid=1&key=&ddns=&af=0&sf=0&atohigh=0&atolow=0&r=35&ron=0&roff=255&r1=254&ron1=0&roff1=255&pwma=0&pwmd=91&pwmao=255&pwmdo=255&sal=60&dcm=2&dcs=0&dcd=40&dct=30
Posted: Wed May 27, 2015 6:08 pm
That looks correct.
I'm really out of ideas.
RA is sending the data to the wifi attachment, which should send it to the portal, but for some reason it is not.
The only weird thing is that 1st character before GET.
If you leave serial monitor open, does it show again?
Posted: Wed May 27, 2015 6:12 pm
by Lionfan
rimai wrote:That looks correct.
No, it pops up as soon as i open up the monitor, but doesnt repeat...
Posted: Thu May 28, 2015 7:54 am
by Lionfan
this morning i got a blinking status light on the head unit.
everything is still running, and I'm still getting data sent to reeftronics.
Don't know what's going on..
Posted: Thu May 28, 2015 11:07 am
That means a bus lock probably.
If you use the joystick to the status screen, what does it show?
What expansion modules do you have connected?
Posted: Thu May 28, 2015 12:04 pm
by Lionfan
rimai wrote:That means a bus lock probably.
Earlier today, everything looked the same when i scrolled thru.
The only expansion module right now is a relay box.
Posted: Fri May 29, 2015 6:57 am
by Lionfan
I had the bus lock yesterday, it cut off my second relay box.
I disconnected the expansion hub, and got the bus lock to go away. but now I'm without the 2nd box.
still having problems with no portal comm.
Is there anything you can do on your end to see if maybe the portal just isn't updating?
Posted: Fri May 29, 2015 10:50 am
I don't see nothing wrong on this end. Portal has been updating for other members.
When you have some time, send me a PM and we can schedule a remote session.
Posted: Wed Jun 03, 2015 10:53 am
by reefaddicts
rimai wrote:I don't see nothing wrong on this end. Portal has been updating for other members.
It's lionfan..
I created a new account, and changed the code on the controller, and I still don't have any data going to the Portal..
I did it the night we had the remote session, and still nothing.
Posted: Wed Jun 03, 2015 11:37 am
This username was giving the same crap as we experienced that day.
So, I knew something was up.
But I finally found the bug
Can you let me know if it is working now and you can switch back to lionfan
Posted: Wed Jun 03, 2015 12:05 pm
by reefaddicts
rimai wrote:This username was giving the same crap as we experienced that day.
Yelp it's working now!
You da man!
I'll switch back tonight and delete this name.
