URGENT - Error uploading Code - Blank Screen
Posted: Wed Jun 03, 2015 9:58 pm
by rrodriguess
Hi guys
I may have a big problem on my hands. I will try to be as clear as possible despite the language barrier.
Last night I came home and my reefangel was working fine. Then I tryed to upload a code through bluetooth as I normally do. I got this error:
avrdude: Recv: U [55]
avrdude: Recv: n [6e]
avrdude: Recv: k [6b]
avrdude: Recv: o [6f]
avrdude: Recv: w [77]
avrdude: Recv:   [20]
avrdude: Recv: C [43]
avrdude: Recv: m [6d]
avrdude: Recv: a [61]
avrdude: Recv: d [64]
avrdude: Recv: . [0d]
avrdude: Recv: . [0a]
avrdude: Recv: R [52]
avrdude: Recv: e [65]
avrdude: Recv: f [66]
avrdude: Recv: A [41]
avrdude: Recv: g [67]
avrdude: Recv: l [6c]
avrdude: Recv: > [3e]
avrdude: Recv:   [20]
avrdude: Recv:   [20]
avrdude: Recv: Q [51]
avrdude: Recv:   [20]
avrdude: Recv: u [75]
avrdude: Recv: i [69]
avrdude: Recv: t [74]
avrdude: Recv:   [20]
avrdude: Recv: & [26]
avrdude: Recv:   [20]
avrdude: Recv: j [6a]
avrdude: Recv: p [70]
avrdude: Recv:   [20]
avrdude: Recv:   [20]
avrdude: Recv: s [73]
avrdude: Recv: r [72]
avrdude: Recv:   [20]
avrdude: Recv: . [1b]
avrdude: Recv: . [10]
avrdude: Recv: . [00]
avrdude: Recv: . [02]
avrdude: Recv: . [0e]
avrdude: Recv: . [13]
avrdude: Recv: . [14] "
and
"avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_command(): failed miserably to execute command 0x1d
avrdude: stk500v2_cmd(): failed to send command"
In th first we can se a vertical message written:
"Unknown command. Reef Angel unknow Command. Quit & junp to user pgm" (what hell?)
Tryed again, and again. Same thing. Turned off my computer bluetooth and turned back on. Nothing. Reboot my computer and... nothing.. same error!!
A few minutes later I decided to take a look at the controller itself. Its screen was gone.. I mean all I got was a blank screen.
Thought to myself: "Ok.. no reason to get worried.. just reboot it by talking off the wall".
Nothing happened... I get the same blank screen and a solid green led.
Tryed to use the TTL cable to upload a code. When I connect the USB cable on my computer I get flashing red led for a few moments and then a solid green led.
Using the TTL cable, the same error occurs "failed miserably to execute...".
By reading some posts with the same error, I double checked:
Water Damage
TTL cable not connect properly
Correct Board
Corret Serial Port
Well.. after 2 hours trying to make it work... I have to say.. I am quite worried. Even If I have to buy a new unit, I am in south america, and can't have the luxury to wait a month to get the aquarium running again.
Can someone help me please?
If necessary I can post photos and videos showing what is going on.
Tks
Rafa
Re: URGENT - Error uploading Code - Blank Screen
Posted: Wed Jun 03, 2015 10:26 pm
Try loading a very simple code like this:
Can you upload this code?
Posted: Wed Jun 03, 2015 10:36 pm
by rrodriguess
Surprisingly I can upload this simple code!
Immediately tryed my oold code.. and got the same error.
Any thoughts?
Posted: Wed Jun 03, 2015 10:38 pm
It has to be something in your code that is causing that behavior.
The controller has a bootloader that has a special diagnostic mode when !!! is sent in sequence.
I think your code is causing the bootloader to enter this diagnostic mode somehow.
Posted: Wed Jun 03, 2015 10:45 pm
by rrodriguess
Worked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
removed my last alteration:
"if(feedMessage==false && ReefAngel.DisplayedMenu == RETURN_MAIN_MODE){
SENDEMAIL=true;
EMAILMESSAGE="Feeding+Mode:+Ended";
feedMessage=true;
Maybe I cannot use if(feedMessage==false && ReefAngel.DisplayedMenu == RETURN_MAIN_MODE) ?
Tks Roberto!!!!!
