Float Switch Causing Bad PH
Posted: Sat Jun 06, 2015 11:13 am
If I unplug my lower ATO float my PH probe reads correctly, also with the float unplugged and the higher float submersed everything is ok indicating an issue with only the one lower float.
Is this typical of floats getting older, they are less than 2 years old?
