Coral Box DC300 Skimmer
Posted: Sat Jun 13, 2015 12:47 pm
by Ismaclst
I'm thinking about maybe buying the Coral Box DC300 Skimmer. Since this uses a Jebao DC pump I thought I could control it with the RA. Right now when I turn off the return pump for feedings, the water raises in the section where my skimmer is at. This causes my skimmer to start overflowing, which causes all the skimmate to go back into the tank. Is there a way I could control the coral box skimmer so the pump slows down when the level gets too high? Not sure of a good way to sense the level inside the skimmer.
http://www.fish-street.com/coral_box_d3 ... _warehouse
Re: Coral Box DC300 Skimmer
Posted: Sat Jun 13, 2015 5:13 pm
by Ismaclst
Just thought of something. Would it be possible to use the water level tube in my sump to slow the pump of the skimmer down? Right now my normal level of my return section of my sump, when its running, is 37. When I turn off the return and the water reaches a designated height it would slow the pump of the skimmer down. Not sure about how to code this, though.
Posted: Sat Jun 13, 2015 6:24 pm
Yes for sure thats the way I'd work it rather than the level in the skimmer. But if there was a way to measure the skimmer it would rock. Tough one that.
You'd just have some set % that you drop to depending on the level in the sump.
if (ReefAngel.WaterLevel.GetLevel()>75) ReefAngel.PWM.SetActinic(50);
Posted: Sat Jun 13, 2015 6:45 pm
by Ismaclst
Great, thanks. Inside the skimmer would be ideal.
Posted: Sat Jun 13, 2015 6:47 pm
by Ismaclst
How would I code that if I have the mult level water expansion and the sump level is on one
Posted: Sat Jun 13, 2015 8:13 pm
I think inside the skimmer would mess with its functionality. Plus all the bubbles would mess with the sensor conpletely. You'd need a diff kind of sensor like optical or something which wouldnt really work properly either. Maybe a sonic one.
Posted: Sat Jun 13, 2015 9:09 pm
by Ismaclst
Would I add a one inside the parenthesis if I have the multi level water sensor and I am using channel 1 for the sump? Like this:
if (ReefAngel.WaterLevel.GetLevel(1)>75) ReefAngel.PWM.SetActinic(50);
Posted: Sun Jun 14, 2015 3:36 pm
Yes. That should work.
Posted: Wed Jun 17, 2015 4:20 pm
by Ismaclst
Ismaclst wrote:Would I add a one inside the parenthesis if I have the multi level water sensor and I am using channel 1 for the sump? Like this:
if (ReefAngel.WaterLevel.GetLevel(1)>45) ReefAngel.PWM.SetActinic(50);
So if I use the above code to run the skimmer when the water reaches a certain level, would I use the code below to run the skimmer when the water drops below 45 or the normal water level of the sump?
ReefAngel.PWM.SetActinic(100);
Posted: Wed Jun 17, 2015 4:23 pm
by Ismaclst
Something like this?
Posted: Wed Jun 17, 2015 7:58 pm
I would get rid of the else and just have the Set at 100 before the if. Then you could just add different water levels with different speeds by just adding more iffs in the correct order
Posted: Wed Jun 17, 2015 7:59 pm
if (ReefAngel.WaterLevel.GetLevel(1)>75) ReefAngel.PWM.SetActinic(25);
Posted: Thu Jun 18, 2015 1:32 pm
by Ismaclst
Ok, thanks.
